3D Naca wing divergence
Like Tree1Likes
Old   March 9, 2013, 14:54
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I was thinking of more smooth mesh. Here it is...
Far is offline   Reply With Quote
Old   March 9, 2013, 15:35
Francisco
Bollonga is on a distinguished road
Originally Posted by Far View Post
I was thinking of more smooth mesh. Here it it . ...
How are those curved edges made? Splines curves?
Bollonga is offline   Reply With Quote
Old   March 9, 2013, 15:47
Far
Sijal
Blocking > Edit edge (s) > Link edge
Source edge : The edge whose shape you need to copy to other edge.
Target edge : Whose shape is to be changed
Factor : 1 -3 . I've used factor of 3
Old   March 10, 2013, 08:18
Francisco
I have used pressure based coupled solver. Other options used are : High order term relaxation. 2nd order flow scheme. Cournt number 20,000.
up and down boundaries are slip walls. Did not specify the turbulence level, used default settings.
It works for me too! You're the man!
I've applied this same setup with k-epsilon Realizable model to the 3D flat plate case with 70º angle of attack I've been dealing with. It's working too! I think the key is the courant number modification.
How does it afect to increase it from default 200 to 20,000?
What is the different between slip zero shear stress wall and symmetry BC?
I'm using default k and epsilon at the inlet but I'm gonna need to modifiy them. Would this make me change the mesh or reducing even more under-relax factors?
For how long should I maintain the reduced under-relax factors? It's making my simulations pretty slow...
Old   March 10, 2013, 10:14
Far
Sijal
It is cournt number for pressure-based coupled solver which couples continuity and momentum equation only. So the definition is not same as the cournt number we study in CFD course.
Fluent guide says, you can increase it to 200,000 and it worked for me for transition modelling of low pressure turbine. In fact this model was used first time for the the low pressure turbine case (i can give you that paper which made use of Fluent's pressure based coupled solver) due to fact that there is strong coupling of continuty and momentum equation. And when Simple type algorithms are used (which couples pressure - velocity fields loosely) they introduce errors for this class of problems and make the convergence difficult.
Both are same except that you need plane surface aligned with any plane for symmetry condition while slip condition can be applied to any surface. In fact I use slip condition due to my past practice. Some friends here always use symmetry condition. But in my point of view results should be same.
Why you want to change them? Do you want to match some test conditions for which you have specific values of turbulence parameters. Any how , you dont need to change any thing.
For pressure based coupled solver, we don't have option for URF!
Old   March 10, 2013, 11:54
Francisco
Yes, I need to match some test turbulence conditions.
In the solution controls panel there's the option to modify explicit relaxation factors for momentum and pressure and under-relaxation factors for density, body forces, k, epsilon and turbulent viscosity. I've reduced to half all that values. Once the solution is converging, can I change them to default without risking the convergence?
Can I change to 2nd order schemes for k and epsilon to get a more accurate solution?
Old   March 10, 2013, 12:06
Far
Sijal
Ah those parameters. You can play with them. Generally speaking, I use default values.
I don't think turbulence needs second order accuracy. If you are not modelling transition type of flows, results wont change much. In transition dominated flows, I have observed no separation at all when used first order turbulence discretization.
Just think, you have already averaged out the quantities and now you want to add the averaged change in mean flow due to turbulence. How accurate would be averaged quantities with 2nd order accuracy . Probably you will get same averaged values
Old   March 10, 2013, 15:08
Francisco
Even if it's converging, CD and CL are far from their correct values. I guess I have to let the simulation run longer. The problem is it's too slow!
I'm simulating the transient case for the 70º inclined flat plate with adaptive timestepping from 1e-3 to 1e-6 but it's always take a timesetp between 1e-5 and 1e-6 s. I've put 50 iterations per timestep.
I need at least 1s of simulation and it taking 1 day to do 4e-4s...
3d wing, airfoil, divergence, turbulence
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
3d vof Smaras FLUENT 2 February 19, 2013 07:58
[ICEM] Blocking For Swept Wing air_engineer_arsenal ANSYS Meshing & Geometry 13 July 24, 2012 12:52
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
NACA wing Imanuel CFX 2 July 22, 2005 02:48
