oscillations in residual/iterations plot
Old   March 6, 2013, 04:36
Default oscillations in residual/iterations plot
Thomas Hoffmann
Thomashoffmann is on a distinguished road
Hi.
I'm simulation a pipe flow with a non newtonian fluid. After about 2700 iterations my residual starts to oscillate (see attached).
Do you know if this is something that I should be worried about? And why it happends?
Thanks
Thomas
Thomashoffmann is offline   Reply With Quote
Old   March 6, 2013, 05:18
OJ
oj.bulmer will become famous soon enough
Perhaps, there is a need for a smaller under relaxation factor.
oj.bulmer is offline   Reply With Quote
Old   March 6, 2013, 05:35
Thomas Hoffmann
ok, I just tried to run it again with a under relaxation of 0.8 and this is what I got - see attached..
It starts oscillating again at momentum residual=3E-4 - the same value as before... I think my result is accurate at this value, I just dont like that it is doing this oscillation thing...
Maybe I just shouldn't worry?
Old   March 6, 2013, 06:01
OJ
Typically such small oscillations are indicative of numerical noise amd all other artifacts, which exist even after the solution has converged. To be honest, though I suggested the URFs, or any other change for that matter to make the residual more smoother, there won't be a significant change in the results beyond a point.
I would plot the parameters of interest on important locations, along with the volumetric mass imbalance, to make sure the solution is converged, rather than worrying about residuals. It may be possible that the resiruals are gradually decreasing but monitors remain flatter, indicating convergence. The measure of convergence is the result you are interested in, not residual!
Regards
OJ
Old   March 6, 2013, 06:28
Thomas Hoffmann
I'll try studying the results..
Thank you for the helpful answer!
I want to plot residual U: vahid.najafi OpenFOAM Post-Processing 11 July 1, 2016 03:54
Plot on a curve Monica FLUENT 1 July 11, 2012 01:24
Transfer low-res graphic file plot to excel plot quarkz Main CFD Forum 3 April 9, 2009 14:54
graph plot anindya Main CFD Forum 2 September 17, 2003 13:00
why can't I plot Y+ value? Jiaying Xu Siemens 2 August 18, 2001 11:56
