February 21, 2013, 04:30 |
Hydrostatic head in fluent
Rep Power: 15 |
I am doing a simple 3D simulation of a vertical cylinder with the inlet boundary condition described as mass flow inlet and outlet boundary condition as mass outflow.
I have also activated the gravity term but I do not see the hydrostatic head in the static pressure contours in the results. Fluent should be able to compute the hydrostatic head once the gravity term is enabled. Can any one tell me what is wrong? Thank you. Last edited by mali28; February 21, 2013 at 06:52. |
February 23, 2013, 05:56 |
Rick
Rep Power: 27 |
Have you set operating density to 0?
Daniele |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 03:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 03:57 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
