Non-premixed Combustion Error: Flamelet Extinguished
Old   February 20, 2013, 12:00
Question Non-premixed Combustion Error: Flamelet Extinguished
Jenny
Jenny_W is on a distinguished road
I am modelling jet reaction using non-premixed combustion model with steady flamelet chemistry.
After importing CHEMKIN mechanism and thermodynamic database files, I fail to calculate flamelets.
FLUENT exits and reports the error "Single flamelet extinguished Try again with lower Scalar Dissipation". I try lowering the scalar dissipation but it doesn't work. I feel it is something related to my reaction mechanism but I cannot point out exactly what the problem is. Does anyone have any idea?
Thank you,
Jenny
Jenny_W is offline   Reply With Quote
Old   July 4, 2013, 02:18
juzer_700 is on a distinguished road
Originally Posted by Jenny_W View Post
Thank you,
Jenny
I imported n-heptance chemkin mechanism file and thermodynamic data file and got the same error "Single Flamelet extinguished. Try again with lower Scalar Dissipation".
I increased the oxidizer temperature from 300 to 600K and then it generated flamelets. But I doubt that is the solution to the problem.
Did you manage to get the solution for this problem?
Regards,
Juzer Rangwala,
Indian Institute of Technology Bombay,
rangwala.juzer@gmail.com
juzer_700 is offline   Reply With Quote
Old   July 4, 2013, 02:49
Thank you,
Jenny
Should I enable 'Liquid Micro Mixing' as n-heptane is used?
Regards,
Juzer
Old   August 19, 2013, 07:38
Jenny
Hi Juzer,
I still cannot figure out why those errors.
My reaction is a simple 1-step liquid chemical reaction. When I turn on liquid reaction, I am able to calculate the flamelet.
Hope this helps,
Jenny
chemical mechanism, chemical reaction, chemkin, non premixed combustion, steady flamelet
Modelling of premixed combustion in a burner rig ThomasS FLUENT 12 September 7, 2018 14:07
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 11:52
Premixed Combustion IS FLUENT 3 July 9, 2010 21:22
Non-adiabatic Premixed combustion through scriptin Mahesh Main CFD Forum 2 April 1, 2007 02:04
Non-adiabatic Premixed combustion through scriptin Mahesh FLUENT 0 March 31, 2007 09:19
