Problem with phase separation in t-junction
Old   February 20, 2013, 04:47
Default Problem with phase separation in t-junction
Elin Stenmark
estenmark is on a distinguished road
I am trying to simulate two phase flow of air and water in a vertical t-junction with a horizontal branch. All parts of the junction have inner diameter 50 mm and are 500 mm long. There is one inlet which is located at the bottom of the junction and two outlets.
I have velocity inlet with known velocities and volume fractions (air: 5m/s and 0.58 volume fraction, water: 6.21m/s). I have a known overall flow split (20/80 in branch/main arm) so first I tried outflow for outlet boundary conditions. I have also simulated using pressure outlet.
As my phases are mixed I am using the Eulerian multiphase model. I'm running transient simulations and have tried both implicit and explicit formulation of volume fraction equation. My primare phase is air. For turbulence I am using the realixable k-epsilon with enhanced wall treatment. I have enabled gravity and surface tension modelling.
I have tried both coupled and segregated solver and first and second order descretization for momentum/energy equations. For volume fraction equation I've been using HRIC.
Now finally to my problem; I get no phase separation in my simulations! There should be more air flowing in to the branch but in my simulations I get almost 50/50 of air and water in the entire domain. All simulations converge (I have 1e-5 for convergence criteria and I run the simulations until mass flow out equals mass flow in).
Does anybody have an idea on what the problem can be? To my knowledge, Eulerian should be the most suitable multiphase model as the phases mix. I have tried refining the mesh but I still get the same problem.
Any ideas/comments would be greatly appreciated!
Sorry for the long post...
Regards,
Elin
estenmark is offline   Reply With Quote
Old   August 8, 2013, 02:17
EMAVI V SURYA SAMPATH
sampathevs is on a distinguished road
Did your problem got solved ?
sampathevs is offline   Reply With Quote
Old   June 3, 2014, 21:18
ali91
abraham91 is on a distinguished road
i also get the same problem
abraham91 is offline   Reply With Quote
fluent, multiphase, phase separation
Thermal phase change set up problem Danial Q Main CFD Forum 1 July 10, 2014 15:41
Problem in modeling membrane gas separation hakim22 FLUENT 0 July 31, 2011 11:28
Benchmark problem in two phase flow Ram Dayal CFX 2 August 9, 2006 00:07
Two phase Eulerian Model Problem senthil FLUENT 5 May 21, 2003 03:55
Geometry setup for phase change problem Fred G. Kang Main CFD Forum 1 October 14, 1998 12:41
