February 19, 2013, 10:34 |
Boundary conditions
Rep Power: 13 |
Hi everybody,
I'm studying, with Fluent, the natural ventilation of a cubic building in a huge fluid domain (as shown in figure) over a basis representing the ground. I've some problems in setting boundary conditions, infact I've formulated within the Meshing of Workbench some "Named Selections", specifically:Velocity inlet 1, velocity inlet 2, velocity inlet 3,velocity inlet 4 and pressure outlet for all the faces of the domain except the floor; moreover I've set the name of all the surfaces of the walls of the building (front, back, left, right and roof, both internal and external) since I've divided all the building walls in many parts in order to have sweapable bodies during meshing. In Fluent I have 3 "Cell Zone Conditions": building, domain and ground. However, setting boundary conditions, Fluent has created many further walls (and shadow walls) which can't be seen in dispaying mesh surfaces but are the only walls that can be edited in the window of Boundary Conditions. Which could be the problem?I've tried to delete the additional walls in "surface manage" but the situation persists. Bests |
February 19, 2013, 10:57 |
Philipp
Rep Power: 27 |
Hi, did you create several parts? I guess what you want is to create multiple bodies and group these bodies to a single part. If you do the second, the grid at the transitions is conformal, i.e. all faces from one body match exactly the faces of the adjacent body. I think the meshing tool made non-conformal transitions and thus needs all these dizzying shadow faces!
Go back to DesignModeler and put all your bodies into one part: mark the bodies in the lowest part on the left ("tree outline") and click on "form new part". I hope your problems will vanish then...
The skeleton ran out of shampoo in the shower. |
February 21, 2013, 12:31 |
Rep Power: 13 |
Thanks for the reply. Indeed I've unify all the bodies under just one part and now I've no problems in setting boundary conditions. But when I try to run, after few iterations I get this message: "Error: Divergence detected in AMG solver: epsilon". It is possible linked to a problem related to the high aspect ratio of feww elements which is reported by Fluent when I check the mesh. However I don't know how to manage this problem, since aspect ratio is very high just in few cells that I can see in the Mesher of Workbench. I don't know how to improve it within these cells and if I've to do this in Fluent or in the mesher (and how). Any suggestion? Thanks a lot. Bests |
February 21, 2013, 13:19 |
Philipp
Rep Power: 27 |
I guess you use the Ansys Meshing uitlity. If you had ICEM-hexa for meshing, I could help you...
Can you post a picture of the mesh? Or you start a thread in the meshing sub-forum.
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 05:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
