Heating value of fuel in non-premixed model?
Old   February 15, 2013, 15:27
Default Heating value of fuel in non-premixed model?
Jerónimo
Jeronimo97 is on a distinguished road
Hi there. I'm simulating combustion of natural gas in a furnace using the non-premixed combustion model. The supposed lower heating value of natural gas is about 46 MJ/kg, but when I see the repport of the simulation of the "Fluxes", and if I calculate manually the heating value, based on the input energy flux through entrance divided by its mass flow rate, I get a heating value of only 4,7 MJ/kg, it's 10 times lower than what I was expecting.
I've tried to see the summary report, to see proprierties of materials and species of the PDF mixture, but it doesn't mention the heating value of nothing.
How can I see and impose the lower heating value of my mixture, without using the "Empirical fuel stream"?
Thanks in advice.
Jeronimo97 is offline   Reply With Quote
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 17:25
Non Premixed Combustion model tanaji FLUENT 0 February 28, 2011 16:12
Turbulent premixed combustion error... XiFoam model achinta OpenFOAM 1 June 23, 2010 06:45
The problem of UDF in Non premixed combustion model zhangyuan Main CFD Forum 0 May 25, 2009 10:41
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 05:37
