February 16, 2013, 18:32 |
#21 |
Alex
Rep Power: 49 |
Is this a picture of the actual mesh you are using?
If yes, add at least prism layers at the walls. What mach number do you expect in your simulation? How high is the pressure at the inlet and outlet respectively? Edit: Am I right assuming that the prism layers you added are so thin compared to the tet elements that they cannot be seen in the picture of your last post? |
February 16, 2013, 18:37 |
#22 |
Rep Power: 14 |
I have added prism layers at the bottom wall.The Mach no is around 0.3. The pressure at the inlet is 103000 Pa and the outlet is what I have to find by comparing the exp results.
February 16, 2013, 18:50 |
#23 |
Alex
Rep Power: 49 |
Since you are experiencing convergence issues, I would try a simulation with a velocity or mass flow inlet, at least to get better initial values for the following simulations.
Getting back to the prism layers, are you sure that the volume jump is better this time? Additionally, I strongly recommend to use a hexa mesh, especially since the whole geometry basically consists of one hexaeder. A good mesh is one thing less to worry about in CFD This could even be done with the Ansys mesher. |
February 16, 2013, 18:57 |
#24 | |
Rep Power: 14 |
February 17, 2013, 01:33 |
#26 |
Rep Power: 14 |
Is there other option than symmetry for modeling slip walls?. Also, but if we extend the domain at the inlet and outlet, it changes the parameters (velocity, pressure) inside the domain right?
February 17, 2013, 02:13 |
#27 |
Specify extended walls as slip so you will not have any boundary layer development or pressure loss.
You can define as slip wall by specifying shear stress = 0. It will have same effect as symmetry. Moreover symmetry condition has some special purpose and it has different mathematical definition. |
February 17, 2013, 02:26 |
#28 | |
Rep Power: 14 |
February 17, 2013, 03:27 |
#29 |
Alex
Rep Power: 49 |
This is the first time I heard of this. Are you sure? Where exactly is the difference?
February 17, 2013, 03:36 |
#30 | ||
I always face convergence problems with symmetry, which is not the case with slip wall.
February 17, 2013, 05:00 |
#31 |
https://dl.dropbox.com/u/68746918/CFDNotes06.ppt
Refer to slide 54 and 57. Why two lateral boundaries are set as symmetry and top and bottom as slip-wall? What will be effect if two side (lateral ) boundaries are set to slip-wall or periodic? What will happen if top and bottom walls are defined as symmetry or periodic? Edit : Some notes from CFX Last edited by Far; February 17, 2013 at 05:45. Reason: Adding pics related to CFX help |
February 17, 2013, 08:42 |
#32 |
Philipp
Rep Power: 27 |
Hi, you should switch off energy equation and try to run the simulation. If that diverges too, please switch the inlet to velocity inlet and try if it works. Pressure inlet and outlet are not the easiest choice.
The skeleton ran out of shampoo in the shower. |
February 17, 2013, 13:10 |
reply for the wind tunnel simulation
#33 |
hossam ali
Rep Power: 13 |
hi i think the problem in ur mesh skewness
u should remesh and decrease the skeness to be less than now and this will decrease the squinsh of the mesh (to be less than 0.9) |
February 18, 2013, 11:24 |
#34 |
Philipp
Rep Power: 27 |
Maybe (or belike) the mesh is the problem, but normally meshing is also the most time consuming part of the whole process, so rather than remeshing I would try to spot the problem before starting...
February 19, 2013, 01:26 |
#35 |
Rep Power: 14 |
I have tried extending boundaries and slip walls. No use. Still it is diverging.
I will try incompressible flow and velocity inlet and simulate once again. |
February 19, 2013, 03:07 |
#36 | |
Philipp
Rep Power: 27 |
Also, if you explain your case in a thread, please tell people everything about it and don't wait until post #50 to do so...
February 19, 2013, 04:57 |
#37 | |
Rep Power: 14 |
February 19, 2013, 05:04 |
#38 |
Philipp
Rep Power: 27 |
My bad! I didn't know that posts have captions. Anyway, switch off all these additional equations when something does not work and try to run it.
April 6, 2013, 15:54 |
#39 |
Rep Power: 14 |
I am facing a new problem now. I got rid of all the previous problems. The solution was taking a lot of time and many iterations to reach steady state. So I have used FMG initialization and pseudo transient method( time step 0.001) to make the convergence faster. When I was trying to find mesh independent solution, after 3rd refinement, the solution (pressure and velocity) started oscillating where it was supposed to reach state.
How did the mesh refinement led to oscillations? If mesh is not the problem, what could be the problem? |
April 6, 2013, 17:08 |
#40 | |
multiphase flow, quick divergence of contuinity eq | violet | FLUENT | 8 | February 16, 2016 06:32 |
[ANSYS Meshing] Very high aspect ratio | zxin | ANSYS Meshing & Geometry | 12 | August 16, 2011 10:49 |
Divergence detected in AMG solver:species-0 | arulmurugan | Fluent UDF and Scheme Programming | 0 | February 15, 2011 05:22 |
non zero divergence for incompressible flow! | Pascal_doran | OpenFOAM Running, Solving & CFD | 17 | September 21, 2010 11:22 |
About divergence for help! | xhliu1 | Siemens | 2 | April 7, 2005 04:53 |
