February 12, 2013, 13:19 |
Spouted bed - Jet penetration / bubbling
Bayard Morales
Rep Power: 17 |
Hello there.
I am modelling a (spouted bed using a euler-euler granular model in Fluent 14. Even though I am following the model choice of some paper which can reproduce quite well the experimental data, I cannot obtain a correct jet regime. The authors of the experimental work state that the spouting regime starts around gas inlet velocity of 38 m/s, but in my simulation I cannot get any spouting. Using around 41 m/s, the gas barely penetrates the solid bed. Using 55 m/s, a bubbling regime happens. Any thoughts on it?? Thanks!! |
October 7, 2013, 11:06 |
mohsen
Rep Power: 13 |
hi
i have a same problem,i want to modeling hydrodynamic of spouted bed my experimental reference is HE et al . diameter of inlet=19mm solid density=2500kg/m3 diameter of solid=1.41 mm inlet velocity=41 m/s H0=325mm H=1000mm initial volume fraction of solid=0.588 drag model= Gidaspow other Authors reach spouting, in my simulation I cannot get any spouting. did you solve your problem? can you help me? thank you in advance |
gas-solid flow, granular flow, spouted bed |
Multiphase liquid-solid spouted bed: pressure problem | ghost82 | FLUENT | 7 | November 10, 2013 13:12 |
HELP : Study of an impinging jet on a sand bed. (Two-phase flow) | free-jet | OpenFOAM | 1 | May 2, 2013 17:26 |
Bubbling Fluidized Bed reactor burning biomass | Mattias | FLUENT | 6 | June 8, 2004 03:53 |
Bubbling Fluidized Bed | Sanjib | FLUENT | 4 | April 20, 2002 04:40 |
Bubbling Bed Fluidisation | sanjib das sharma | CFX | 0 | January 29, 2002 11:36 |
