Animate transient data in Fluent using a set of .dat files |
February 6, 2013, 03:12 |
Akash
Rep Power: 13 |
I have a set of .dat files corresponding to results after each time step of a transient problem. How can I animate the results in Fluent without any other software.
P.S. : I had trouble in animating the results in CFD-POST, as I wasn't able to select the desired location ini Contour plot. |
February 7, 2013, 07:37 |
Mamdouh
Rep Power: 14 |
Hi Akash,
did you tried to build up a FLUENT journal file to successively open, read, and apply you .dat files? Just suggestion GOOD LUCK Mamdouh |
.dat, animation, postprocessing |
Fluent case and data files to OpenFOAM format | chittipo | OpenFOAM Running, Solving & CFD | 11 | March 9, 2013 08:28 |
How to show the transient case? | H.P.LIU | Phoenics | 7 | July 13, 2010 05:31 |
Fluent 6.2.16 on cluster saves data files slowly | cle3000 | FLUENT | 2 | May 21, 2007 10:54 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
Tecplot Variable Names For Fluent Data Files | Simon | FLUENT | 0 | September 22, 2005 11:44 |
