The effect of setting parameters on the roll type flow
Old   February 5, 2013, 12:55
Default The effect of setting parameters on the roll type flow
sa
saharesobh is on a distinguished road
Hello every one,
Hope you are all doing great. I have a question. Actually I am evaluating the effect of the setting parameters (pressure, temperature, velocity and viscosity) on the flow behavior( for instanced longitudinal and transversal roll). For instance, I saw that when I increased the velocity in Ansys Fluent, the roll type flow appeared, but when I increased the pressure the change on the flow pattern was very intangible( minor). Actually all of my result comes from my observation. For example, by looking at the vectors, I figured out the pressure did no have much effect on the flow behavior. Because I did not see much change. My question is that is it any other criteria other than observation of the vectors? Would you please give me some suggestion?
Thanks in advance,
saharesobh is offline   Reply With Quote
Old   February 9, 2013, 17:49
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by saharesobh View Post
Hello every one,
Thanks in advance,
Dear Sahar,
It seems that you are newbye in CFD!! There are some parameters which should be checked such as: shear stress at the wall, pressure distribution along the pipe, average velocity or core velocity along the pipe, heat flux at the wall (if energy is solved), y+ value along the wall (if flow is turbulent) and so on.
Goodluck.
syavash is offline   Reply With Quote
second order schemes marine OpenFOAM 67 April 11, 2022 19:19
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 07:00
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 23:55
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 07:22
Warning 097- AB Siemens 6 November 15, 2004 05:41
