Methane fire
Old   February 2, 2013, 06:20
Default Methane fire
Mohamed
Bido14 is on a distinguished road
Please help and advise how to establish a steady fire using methane
Bido14 is offline   Reply With Quote
Old   February 3, 2013, 05:20
SSL
msaeedsadeghi is on a distinguished road
You can use non-premixed combustion or eddy-dissipation models. In non-premixed mode you should first make a PDF table.
At first you should define if it is a non-premixed flame?
msaeedsadeghi is offline   Reply With Quote
Old   February 3, 2013, 05:34
Mohamed
I think it is not a non premixed.
It is a pipe of methane in the atmosphere.
I have previously used the finite rate/eddy dissipation but couldn't ignite it
Old   February 3, 2013, 05:40
SSL
Is it unsteady?
You can use spark ignition. both reactants, oxidants and products should be avalable at the spark zone.
Old   February 3, 2013, 06:12
Mohamed
I use a steady model, with methane at 1000 K to avoid spark. is that correct?
Old   February 3, 2013, 07:00
SSL
No, You should use a hot spot for initizalization of ignition, like a point with high temperature.
Old   February 3, 2013, 08:14
Mohamed
Can you please clarify what is a hot spot, and how can i make it?
In the case of using it, shall the methane be entered at room temperature and then pass by it to ignite?
Car park ventilation and impulse fans guillaume Phoenics 9 October 27, 2015 06:57
Wildland surface fire representation in OpenFOAM Bufacchi OpenFOAM 0 June 4, 2010 13:07
Fire simulation in Steckler room Per Burström CFX 2 March 27, 2007 20:01
Methane Combustion Lars FLUENT 4 March 5, 2003 09:24
Temperature errors on fire simulation? raymond Siemens 0 January 10, 2002 21:32
