fluent's "outflow" BC not compatible with Singhal cavitation model?
Old   January 31, 2013, 01:26
Default fluent's "outflow" BC not compatible with Singhal cavitation model?
Aditya Pandare
aditya.pandare is on a distinguished road
I am simulating a cavitating flow in fluent 14.5 and trying to use the Singhal et al cavitation model for the same.
Due to the peculiar flow conditions, I have to use the "outflow" BC at the outlet.
but when I try to run the Singhal model with outflow, it gives 2 errors:
1. outflow cannot be used with cavitation model
2. divergence detected in AMG solver ( all the eqns: k, e, x,y,z momentum, pressure correction)
but I can run the same simulation with Schnerr-sauer cavitation model
so is it the case that only the Singhal cavitation model is not compatible with "outflow"? or is there something wrong with my case setup?
any help will be useful!
thank you
aditya.pandare is offline   Reply With Quote
Old   October 24, 2013, 09:27
Sarang
sarodesr is on a distinguished road
Just wondering how did you use Singhal Model in fluent v 14.5. As per my observation, in cavitation model only two models are shown by fluent 1) Schnerr-sauer 2) Zwart-geber-Blmari.
I tried to search but didn't find. Did you write UDF/UDS for the same.
regards,
Sarang
sarodesr is offline   Reply With Quote
Old   October 24, 2013, 11:16
Andrew Kokemoor
Kokemoor is on a distinguished road
My limited experience with the Singhal et al model found it to be very unstable and sensitive to mesh and initialization. It may simply take some patience and experimentation to find the right conditions for convergence.
I'm not sure why your outflow condition might work with Schnerr-Sauer. The Fluent User's Guide says under 6.3.10 that outflow can't be used with any multiphase models (presumably because the mass balance correction doesn't work with multiple phases).
Kokemoor is offline   Reply With Quote
Old   October 24, 2013, 14:16
Aditya Pandare
Sarang, after you select the Multiphase model in the models tab, use "solve/set/expert" in the text command window. enable the Singhal cavitation model.
Kokemoor, yes you are right. actually I found this out long back, but forgot to update here; thanks anyways.
mixture model for cavitation mech5190 FLUENT 12 December 7, 2016 04:24
Cavitation model Esmr CFX 1 November 20, 2012 08:30
Errorin subroutine appeared when applying cavitation model pitisrisuk CFX 1 July 2, 2012 04:36
Cavitation model with non-isothermal flow pitisrisuk CFX 0 July 14, 2009 15:30
Cavitation Model Validation Neil Main CFD Forum 0 January 8, 2004 09:47
