simuilation Combustion in IC engine
Old   January 30, 2013, 01:23
Default simuilation Combustion in IC engine
Amit
amitbdt143 is on a distinguished road
Hello everyone,
I'm trying to simulate the IC engine combustion by using ANSYS 14.I'm able to compile the UDF's and hooked it but after running the 0.25 crank angle it is giving following error,
999999 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 8 bytes: No such file or directory.
I have attached the screen short and also the UDF's please check and try to heip me to solve this error.Untitled.jpgUntitled.jpg
initialize.c
laminar_flame_speed.c
work.c
amitbdt143 is offline   Reply With Quote
Old   March 28, 2013, 04:12
Upendra Garg
Upendra is on a distinguished road
Hi amit,
i am also simulating same problem as u have done related to 2d simulation of SI engine combustion and have to use the same 3 UDFs. I am not
able to load these files from "compiled UDFs" panel and hence not able to hook the functions defined. Can you provide me any suggestion from your experience. It would be useful to me in my project.
Thanks
Upendra is offline   Reply With Quote
Old   March 29, 2013, 08:49
Amit
Hi Upendra
what is the error you r getting while hooking the UDF's
Regards
Amit Kumar
Old   March 29, 2013, 16:00
Upendra Garg
I have attached image of screen showing error. I searched on this forum and came to know that it was occurring because fluent could not be linked to C compiler. So i installed microsoft visual studio and defined required environment variables. Thank god...i was able to rectify the error .UDFs were built and loaded.
were u able to run your tutorial fine? Did it produce physical results? In my case
i was able to run the tutorial as per given instructions...but did not get physical results. At spark time flame front is formed but ..it is not sustained. Because of that i did not observe much rise in avg. pressure during combustion....it seemed as if air was only compressed not burned.
Old   March 30, 2013, 00:39
Amit
Dear Upendra,
Then now you are able to hook and run the combustion simulation right. And regarding me I have initially worked on 2D combustion and now moving on with 3D but still not succeed to establishes the required results. Please can I Know on what type fuel are you working.
Regards
Amit Kumar
Old   March 30, 2013, 16:26
Upendra Garg
i have to work on methane. But i think my combustion is not happening right. As i mentioned ..flame only initiates at spark timing ..and extinguishes after few cranks only...i don't know what could be the reason...i have attached the tutorial file i am referring to for simulation.
Did u face any similar problem ?
Old   April 1, 2013, 08:20
Amit
Dear Upendra,
I couldn't get the attached files You have sent.
Old   April 1, 2013, 14:13
Upendra Garg
Hi Amit,
Thanks for your responses. Well, i was able to run the tutorial fine with combustion. my previous problem has been sorted out.
Now i have another problem with the mesh that i myself created. The mesh is ok and has no problem. When i set up the case (as per instructions in tutorial manual) and ran it on fluent..after few iterations it shows following error.
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save cas/data under new name.
3. Exit programme and restart to continue.
4. Report error to your distributor.
Error object
l
Did u face such problem with your own mesh.?
I am using the same three UDFs for initialization, laminar flame speed and work. I found somewhere that it could be because of UDFs.
Do u have any suggestions?
link for tut file:
https://docs.google.com/file/d/0B_05...it?usp=sharing
Old   April 2, 2013, 01:17
Amit
Hi Upendra,
I'm not able to access your drop box link, so i have not downloaded your tutorial file.And regarding the error, i have also faced the same problem, but it can be sort out by changing the cell ID number of piston from tutorial zone ID number to your case file zone ID number.
Regards
Amit Kumar.
Old   October 15, 2013, 12:19
CHHATTISHGARH
gullu is on a distinguished road
can you send me any modeling tutorial............please
gullu is offline   Reply With Quote
Old   November 24, 2014, 06:59
naveen kumar
naveenkumar10792 is on a distinguished road
In my M.Tech project I am trying to simulate an ic engine . . . can anyone help me how to start . . .
and also i need the required tutorial files . . .
can any one send those files please . . .
www.naveen10792@gmail.com
naveenkumar10792 is offline   Reply With Quote
naveen kumar
Diesel Engine combustion chamber analysis sachinthakre FLUENT 12 August 13, 2013 15:14
Combustion Modeling in internal combustion engine Joeyt FLUENT 3 May 26, 2013 06:30
Stratified Charge Engine Combustion Chamber Design AdamL OpenFOAM 15 January 27, 2012 21:47
CFD of combustion process of Homogeneous Charge Compression Engine (HCCI) kelvinlim Main CFD Forum 2 January 26, 2012 23:19
combustion in internal combustion engine George Main CFD Forum 0 September 7, 2006 15:41
