How to create a tank which partially filled with fluid?
Like Tree2Likes
Old   February 13, 2013, 06:30
ORYON is on a distinguished road
Originally Posted by RodriguezFatz View Post
Now, what was the problem?
here is the region( horizontal inlet) where the viscosity ratio is more than 1e5. How can i improve the mesh quality of that specific area?
ORYON is offline   Reply With Quote
Old   February 13, 2013, 07:46
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Ok, some thoughts:
1) Do you really need the small inlet pipe? This is numerically painful, because the length (and therefore also timescale) of the pipe is much smaller than the one of the tank. Can't you just imprint an inlet surface to the pipe wall and use this little surface as an inlet?
2)I wouldn't use a prism layer at the tank wall. You normally use them, when the flux is parallel to the wall (such as in pipes, at wings,...). Then, the main advantage is, that you can resolve the flow in one direction (perpendicual to the wall) and not too much in the others. Also some numerical errors cancel, when the flux is perpendicular to the prism surfaces. This is not the case in your setup: the flux is not strong along the tank surface! I don't see any sense in a refinement there. A refinement at the inlet and the region where the inlet flow flows along would be good!
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   February 14, 2013, 15:34
Default semi circular flow
  #43
niru
Niru is on a distinguished road
I have an orifice in the ground from where liquid pool starts coming.
The liquid pool is supposed to spread in a semicircular direction.
How to specify flow direction for this condition?
In the normal cartesian coordinate system the pool is to spread in negative and positive y direction and in positive x direction alone.
I am not able to specify (+1 & -1 for y axis) . Is there a way to do it?
Niru is offline   Reply With Quote
Old   March 14, 2013, 15:27
Default reg LNG material properties
  #44
niru
Can you tell how the properties (density , latent heat , boiling point) that are varying with temp were given as input in CFX.
What type of material was chosen (pure substance,mixture , refrigerant?)
Old   May 1, 2018, 06:05
Default water volume fraction created opposite direction
  #45
kites is on a distinguished road
the water volume fraction is changed .it should have been horizontal.kindly help
kites is offline   Reply With Quote
Old   August 25, 2020, 14:28
Suraj prakash
srjprakash is on a distinguished road
I'm conduct a filling simulation which is filling heavier density liquid into a tank which is partially filled with lighter density liquid. Let say the total height of the tank is 10m and partially filled with 3m water. Stratification will happen during filling.
My question is how to create the geometry of this tank and related setting by using Fluent 14.0?
Hi, i am also trying to understand the stratification of LNG in storage tank and facing the same problem that how to make geometry. So, can you please help me regarding this.
srjprakash is offline   Reply With Quote
multiphase mixture, partially filled tank, stratification
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
partially filled tank, evaporation at liq-vap. prasanth FLUENT 5 July 24, 2013 18:12
How to create multiple solid fluid domain? Mishar FLUENT 0 January 25, 2005 04:05
injection of fuel into tank filled with fuel mujahid FLUENT 1 February 19, 2004 07:36
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
