What are the points in simulating 2D airfoil?? |
January 10, 2015, 07:11 |
#21 | |
Charles
Rep Power: 15 |
It's all about referential. Think of it this way, if you put a GoPro on an aircraft wing. From your point of view the wing will not move while the air will be flowing towards the wing. That is the case you want to simulate with CFD. (like this : http://youtu.be/0TNV2xRiTK4) Simulating real life case is possible if you use a boundary condition with zero velocity and make your object move in the domain with variable mesh. This have zero interest obviously. |
How to Connect Points in Design Modeler to make airfoil profile (2D) | andrew_diablo | CFX | 3 | July 7, 2017 06:23 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? | ANT | ANSYS Meshing & Geometry | 2 | July 23, 2012 16:25 |
Simulating a moving airfoil in hovering condition | quarkz | Main CFD Forum | 0 | November 12, 2010 19:44 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
