solidification and melting with VOF: how to sink solid PCM as it melts? |
August 8, 2015, 01:15 |
#21 | |
Arash Silver
Did you find any solution to this? If so, please help me. Regards Arash |
November 15, 2015, 12:02 |
#22 |
Parsa
April 11, 2016, 15:59 |
#23 | |
Rami
Rep Power: 10 |
Do you know the reason for usual selection of an initial temperature of the PCM higher than the liquid temperature in the case of fully liquid or lower than the solidus temperature in the case of the fully solidified rather than using the exact PCM solidus and liquidus values in FLUENT? As I know the FLUENT considers the liquid fraction = 1 for the liquidus temp and 0 for the solidus temp. Is this just related to the accuracy of the results and just to ensure convergence? |
April 14, 2016, 08:06 |
#24 | |
Rami
Rep Power: 10 |
June 8, 2016, 04:02 |
solidfication & melting VOF function
#25 |
vijay kumar
can any one have have the steps for melting of ice in ansys fluent .. please share the steps
September 16, 2016, 15:16 |
#26 |
vishu
In order to give different thermal properties for solid and liquid phases. I think the following description may do the task.
If you take density not as a constant value but as a function of temperature (say piecewise linear function), you can set one value for below melting point (i.e. for solid) and one value for above. |
September 16, 2016, 15:17 |
#27 | |
vishu
In order to give different thermal properties for solid and liquid phases. I think the following description may do the task. If you take density not as a constant value but as a function of temperature (say piecewise linear function), you can set one value for below melting point (i.e. for solid) and one value for above. |
November 3, 2016, 22:59 |
#28 | |
Peter Aestas
Rep Power: 12 |
I am trying to solve a similar problem,like ice melt. In order to solve the move of solid, i try to add a gravity force source to the y momentum. DEFINE_SOURCE(solid_source, cell, mix_th, dS, eqn) { real source; cell_t c; real x[ND_ND],r; real m_lg,a,b; Thread *pri_th, *sec_th; pri_th = THREAD_SUB_THREAD(mix_th,0); sec_th = THREAD_SUB_THREAD(mix_th,1); m_lg = 0.0; if (C_LIQF(cell,pri_th)==0) { m_lg = -9.8*C_R(cell,pri_th); } else { m_lg = 0; dS[eqn] = 0; } return m_lg; } but still it did not move. Can you help me? |
November 4, 2016, 16:00 |
heat exchangers
#29 |
m
Rep Power: 10 |
Hi all, I want to do a project about Numerical simulation of heat exchangers with phase-change material with the help of Fluent.
For example, air from the inside of phase-change material between two parallel plates are passed, and We want more cool air to keep output As shown below: What options should be activated and how that process performed?Please please help me , If it is possible…. thank you. Last edited by mehradahmadi; November 6, 2016 at 14:53. |
November 23, 2017, 21:10 |
#30 | |
Rep Power: 12 |
Hamada, You need to specify temperature dependent properties for your PCM by using a UDF. I suggest you consult UDF manual for "property" related UDFs. Hamid |
November 23, 2017, 21:18 |
#31 | |
Rep Power: 12 |
Rami, If you set the initial temperature exactly equal to the liquidus temperature a very small temperature fluctuation due to round-off errors or any other numerical swing may result in dramatic change in the source terms related to the phase change and creates numerical instabilities. That's the only reason. Good Luck, Hamid |
October 22, 2019, 18:34 |
#32 |
Djamila
Rep Power: 10 |
November 15, 2019, 07:27 |
#33 | |
Rep Power: 16 |
That is useful.... Thanks |
vof phase change |
PCM melting inside the Al cavity | shoxan | FLUENT | 1 | August 9, 2018 03:12 |
VOF with melting of Phase change materials | sakil2k3 | FLUENT | 3 | March 17, 2015 16:26 |
How can I make the solid PCM to sink to the bottom as it melts? | Lim | FLUENT | 6 | December 22, 2014 03:29 |
Laser vof melting solidification injection | Michael | FLUENT | 0 | February 20, 2007 22:28 |
vof + solidification melting | James | FLUENT | 0 | November 29, 2002 11:56 |
