January 24, 2013, 10:06 |
Is this possible with FLUENT 14.5?
Rep Power: 14 |
Hi there
I have to define an additional equation for the species transport case such that the source term in fluent's governing equation itself becomes a variable (and hence the above mentioned additional equation is required) .... is this possible with FLUENT? or any commercial CFD solver? Also I have to prevent FLUENT from using its energy equation instead use my defined energy equation.is this too possible? any help is appreciated ... thnx in advance! |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
How to enable GPU computing using Fluent 14.5? | epc1 | FLUENT | 1 | January 4, 2013 14:19 |
Alias problem when starting FLUENT from command line | batch_error | FLUENT | 0 | May 24, 2012 09:20 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
