January 21, 2013, 13:53 |
simulation of multyphase heat exchanger
giovanni spoleti
Hi!
I want to study a heat exchanger, with water (affected by phase change )on the one hand, and other air. What's the better multyphase model?Why? Why I don't be able to use a polynomial density for water lyquid and water vapour?(the air is considered as ideal gas) |
density, heat exchanger, multyphase |
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 07:33 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 03:21 |
Heat Exchanger Simulation | tightaznbreaka | FLUENT | 0 | March 18, 2010 16:45 |
Diesel combustion simulation ( Heat release rate) | venkatesh | Siemens | 2 | April 29, 2009 08:38 |
need help for using user defined heat exchanger | sinha | FLUENT | 2 | August 6, 2007 18:16 |
