Seeing results at different time steps of a transient solution. |
Rep Power: 0 ![]() |
Hello!
I'm in the process of simulating a pulsating jet flow in 3D using LES, and have done so successfully, I'm just wondering is there a way to see the results of a simulation at different time steps, therefore allowing me to actually see how the flow developed. Is there any way to do this once a simulations been completed? Any help's appreciated, thank you! |
Yanlong Li
Rep Power: 13 ![]() |
use tecplot
Thanks. I'll check, but I'm pretty certain I don't have access to tecplot. Is there any other way?
Philipp
Rep Power: 27 ![]() |
You can only do that if you saved the information during calculation (under "calculation activities), but not afterwards. You can create these animations in fluent ("Solution Animation") or with other programs as well. But in any case you need to start recording during/before your calculation.
The skeleton ran out of shampoo in the shower. |
Ganapathy Iyer
Rep Power: 17 ![]() |
This is what I do.
Write out the Velocity file at a predetermined scene using the execute commands for each time step. This gives me a bunch of JPEG files for each timestep. Then I stitch together these files using http://www.lcdf.org/gifsicle/ This gives me a animated GIF which I can view, as well as use in Reports |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Time averaging results from a transient run | Flow Squad | CFX | 4 | October 24, 2011 10:11 |
transient limit is 99,999 time steps? URGENT | azmir | Siemens | 2 | April 15, 2007 23:06 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 13:32 |
