Plz. Help Required : Drilling Simulation in ANSYS |
January 17, 2013, 08:49 |
Aqsa
Dear All
I am new on this forum and exactly don't know how to use this forum . I will be grateful to you people if you can solve my problem I am working on my project of PVD ( physical vapour deposition) coated drill bits and comparing its different parameters with simple un-coated drill bits. The drilling will be perfome on Plain Carbon Steel ( 1045) on CNC Machining Centre and temperature will be measured with Infrared Thermometer Gun at various positions and inside holes of plain carbon steel plates. I want to do Simulation of it on ANSYS software that how heat is distributed in the material during the drilling operation . Can you plz. tell me what parameters and values should I consider in order to have successful simulation ? What values or dimensions that I can get from this simulation ? And finally how to perform this simulation ? Will be highly grateful for any help and suggestion in this regard Thanks in Advance Aqsa |
April 25, 2013, 04:13 |
Deform 3-D software is available. used to do machining simulations. that might be helpful.
Tutorial files on SI engine simulation using ANSYS FLUENT | Upendra | FLUENT | 0 | September 27, 2012 12:57 |
Ansys Fluid flow simulation for a cooling system help!!! | pradon16 | ANSYS | 0 | July 24, 2012 11:15 |
prob with FSI in ansys. Help required urgently | sumeet | Main CFD Forum | 1 | January 5, 2006 05:06 |
* urgent help required for simulation of pipe flow | mei | Main CFD Forum | 3 | July 3, 2002 05:22 |
Ansys Macro for Cd and Cl required | Iain Johnstone | Main CFD Forum | 0 | February 22, 1999 18:17 |
