Discrete Phase Modeling (DPM) for Liquid Fuel Combustion |
#21 |
Anusai Ramankutty
Rep Power: 7 ![]() |
Hi all,
I am trying to simulate hot flow in swirl stabilised combustor. Atomiser model used : pressure swirl. When i run, the residuals are not converging. Also the dpm plots such as mass in domain, mass evaporated etc is also fluctuating cyclically. I am also getting a warning message : Atomization model is not valid under the conditions (every 700th iteration). How do we check convergence in this case? Hereby attaching the plots. Screenshot from 2020-03-30 09-00-27.png Screenshot from 2020-03-30 09-00-06.png Screenshot from 2020-03-30 08-59-46.png Screenshot from 2020-03-30 09-00-49.png |
#22 |
If you are getting a Warning that the model is not valid, then certainly there are some conditions that are not matching with those for the pressure-swirl atomizer to work. LISA model, on which this model is based, requires few checks to be done. If the field parameters do not pass those checks, Fluent gives this warning. It could be that flow is not enough to cause instability that is required for the breakup and won't cause any droplets to form.
As far as the simulation is concerned, residuals look alright. The jumps in the monitors are due to injection of particles. The residuals and source values change whenever the particles are injected and those are not injected at all time-steps. So, you need to have a re-look at the setup and the conditions.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
#23 |
Anusai Ramankutty
Thank you for your reply. So in this case, what are conditions i need to check?
And how to evaluate the convergence of the solution? |
#24 |
I'd recommend you to go through the relevant paper
https://www.researchgate.net/publica...the_Near_Field
#25 |
Rajasekar
Hi i am also encountering same problem in my simulation, did you find any solution for that if it is shared it would be helpful for me |
Discrete phase modeling on porous media | magnounibo | FLUENT | 0 | April 9, 2009 09:18 |
uncoupled discrete phase calculations | AMV | FLUENT | 0 | December 3, 2003 08:21 |
Discrete Phase Modeling | revanth | FLUENT | 8 | July 18, 2002 06:30 |
Discrete Phase Modeling | Chris | FLUENT | 0 | November 20, 2000 14:08 |
Discrete Phase Modeling | Fred Kang | FLUENT | 3 | October 18, 2000 11:23 |
