January 9, 2013, 09:43 |
Moving equipment in large model
Gerrald Gelderblom
Rep Power: 14 |
Hi all,
I need to model mixing a large tank (a cylinder of r=20m and h=6m) with three or four mixers of two types (d=6m slowly rotating rotors and d=0.5m fast rotating impellers). the axis of the mixers horizontal (while the axis of the tank is vertical). For this problem I need to model free surface flow, transient effects (homogenization), temperature effects (so the energy equation), non-newtonian behaviour and turbulence effects. I think this makes it a rather complicated problem. In order to reduce the problem, I'm thinking of an alternative for MRF approach as follows: First model the impellers in an infinite domain Draw a cylinder around the impeller and obtain the solution for the velocity at the cylinder surface. Draw an equal same cylinder in the tank around the impeller Enforce the velocity profile obtained from the impeller on the surface of this cylinder using UDF's. What do you think of this solution, or do others have experience with this idea? I am still a beginner in Fluent so before I spend time in working out the idea I want to have some advise on the feasibility. Thanks in advance, Gerrald Gelderblom PS. If somebody has other tips and tricks for tackling such a problem, you are very welcome! |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
How to model many small holes in a large domain? | Bryan Woods | FLUENT | 3 | February 5, 2009 20:34 |
problem in large scale model | limingtiger | Siemens | 0 | July 30, 2005 04:59 |
Large Atmospheric Model | Rhydar | CFX | 0 | June 28, 2002 04:01 |
Searching a Software which can model moving objects | Hao Yu | Main CFD Forum | 1 | May 15, 2000 10:42 |
