which turbulence model is better in turbomachinery ?
Old   December 26, 2012, 10:37
Default which turbulence model is better in turbomachinery ?
aysiyi
Aysiyi is on a distinguished road
hi
guys ,i am now simulating a centrifugal compressor in FLUENT 14, in the process , i have a question , which turbulence model is better for turbomachinery? in the fluent training document ,i found that realizable k-ε is recommended in turbomachinery .
so what do you think ? can you share your opinion?
thanks
Aysiyi is offline   Reply With Quote
Old   December 26, 2012, 11:06
cric92 is on a distinguished road
There might be no correct answer when RANS is concerned. K-epsilon model is not good capturing separation. Realizable K-epsilon is better then standard K-epsilon. If you can mange y+~1 you should go for SST K-omega.
cric92 is offline   Reply With Quote
Old   December 26, 2012, 13:07
cfd seeker is on a distinguished road
SST kw is generally recommended for turbo-machinery applications. According to my experience there is always a transition in turbo-machinery flows but 2 Equations RANS models are not capable of predicting transition. However Fluent has introduced two new turbulence models for transition prediction i.e k-kl-w transition (3 eq.) model and Transition kw (4 eq.) model but their mesh requirements are very stringent in the boundary layer(i.e wall y+ <1) and also out of the boundary layer( sufficient mesh resolution in the stream-wise direction and small growth of mesh size away from the boundary layer).
Hope it helps you
Regards
cfd seeker is offline   Reply With Quote
Old   December 26, 2012, 21:12
aysiyi
i will try ,3k
Old   March 2, 2013, 13:27
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
I saw new phenomena in FLUENT forum and i m not sure if it exist in other CFD- forums i.e. at the last few days we hear that somebody design a software called it the name he like and start send declarations about it for getting money? I am wondered this forum is free so why these people permitted to ask for money and not share there knowledge (if they really experts) freely? I hope forum moderators give an opinion about this?
Originally Posted by cfdman7 View Post
Hi dears,
Use this interesting new technique: ECFDG
Choosing the Precision and Solver Type, the Turbulence Model and its Options, and the Radiation Model and its Options are the essential parts of many CFD simulations in ANSYS FLUENT software. These selections depend on numerous parameters and interactions between these parameters. Certainly, the most appropriate selection leads the simulation to the most reliable result. ECFDG software pioneers unique forms for these choices. Simply, fill in the forms and send the generated data; afterward, central ECFDG intelligence program will analyze the data and provide an individualized report for your CFD simulation.
www.ecfdg.com
kbaker is offline   Reply With Quote
turbomachinery, turbulence model
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 21:21
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 04:41
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 05:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
