Axis Symmetry BC
Old   December 11, 2012, 07:04
Default Axis Symmetry BC
Manish
Manish Kumar is on a distinguished road
Is it necessary that in FLUENT the axis symmetry boundary should be aligned with x-axis. Is it possible to apply 'axis' as boundary condition to axis aligned with y-axis. I am applying this axis symmetry condition for first time, so had doubts.
kind regards..manish
Manish Kumar is offline   Reply With Quote
Old   December 11, 2012, 11:58
ATD
Aleksander
ATD is on a distinguished road
You can align axis symmetric boundary on any axis you like. You just have to indicate the axis for the boundary.
Good luck
ATD is offline   Reply With Quote
Old   December 11, 2012, 13:15
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Good luck
Not true; if the axis is y or z you will get amg error; for axis symmetric problems the axis of symmetry MUST be x!!!
Daniele
ghost82 is offline   Reply With Quote
Old   December 11, 2012, 13:43
Lucky
Daniele
axis of symmetry must be X-axis as Daniele mentioned.
Good luck
You cannot set the axis.
Old   December 11, 2012, 15:30
Manish
thanx ghost82 and LuckyTran
actually amg divergence error was the problem i encountered so asked to be fully sure of my thoughts..
Old   May 26, 2023, 06:36
Haider Ali
charade_4eft is on a distinguished road
Is it possible to specify "axis" parallel to x-axis?
charade_4eft is offline   Reply With Quote
Old   May 26, 2023, 13:00
Lucky
No, axis must be a boundary that lies exactly on the x-axis within tolerance or you will get a warning and error
You must translate your geometry such that the x-axis is the rotation axis
axis symmetry, fluent
Warning: Symmetry zone should actually be an axis Gerd FLUENT 1 August 13, 2021 03:28
[ICEM] what's the different between SYMMETRY and AXIS realstoneman ANSYS Meshing & Geometry 8 February 14, 2013 13:10
Symmetry or Axis B.C ?? L. Hamid Main CFD Forum 2 May 20, 2011 07:27
[ICEM] Symmetry axis not present in pre fipellac ANSYS Meshing & Geometry 0 May 20, 2011 06:53
regarding axis of symmetry bunny FLUENT 0 January 3, 2011 05:19
