Simulating Heat Transfer in a Parabolic Trough concentrating Solar collector receiver
Old   December 8, 2012, 14:21
Default Simulating Heat Transfer in a Parabolic Trough concentrating Solar collector receiver
Ashley
Ash_Mech_Eng is on a distinguished road
Hi all,
I am currently trying to simulate radiative heat transfer in a solar collector receiver using Fluent. The collector consists of multiple solid and fluid zones, the outer glass tube, the evacuated annulus region, an inner glass tube and the fluid medium through which the heat transfer fluid is circulated.
The heat transfer fluid inlet temperature is 50 degrees celsius and I am hoping to gain an outlet temperature of at least 250 degrees celsius.
I would like to apply a direct solar irradiance of 32000 W/m2 to the outer glass tube and allow the solver to compute the intensity attenuation throughout the domain to find the heat transfer due to this concentrated solar insolation.
Currently i am experiencing a number of problems
- Trying to represent an evacuated region using a created vacuum material causes an error in the AMG solver
- using small values for the density and near infite values for the specific heating capacity to resemble a vacuum results in all of the heat being dissipated in the vacuum and the inner tube and fluid remain at 50 degrees celsius
-Although i have applied direct radiation of 32000 W/m2 in the radiation tab on boundary conditions, its higher than this in regions within the domain although radiation should be scattered and absorbed by the glass as it travels through the domain
Is this simulation possible using this software? Is there anything fundamental that i may be missing? Can anyone help me?
If you require any further model description please let me know
Kind Regards
Ashley
Ash_Mech_Eng is offline   Reply With Quote
Old   December 10, 2012, 12:02
dking
dsking is on a distinguished road
I have also tried to use radiation models in fluent to no avail. This problem sounds similar to simulating a greenhouse, maybe you could search for greenhouse simulations with radiation models and get some hints from those.
Also you could try to model the vacuum as a semi-transparent solid with a very large Cp and small k. Sounds like a fun problem though, good luck.
dsking is offline   Reply With Quote
discrete ordinate model, fluent 14, heat transfer modelling
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 17:29
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 18, 2014 00:45
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 05:07
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 10:25
