Parallel Efficiency
Old   December 4, 2012, 16:12
Default Parallel Efficiency
Rambod Mojgani
rmojgani is on a distinguished road
If I have 2 case which scenario would be more efficient to solve several cases?
Assume I have 8 CPU cores and two case to be run.
1) using all the 8 cores for solving a case and then going to next
2) use 4 cores for each case , and run both cases simultaneously
rmojgani is offline   Reply With Quote
Old   December 5, 2012, 05:31
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
2nd case is always faster! Running two different simulations at the same time will utilize the cpu much more than the solver can do it. Parallel programming (=1st case) can never use exactly 100% computational power of each cpu because of idle times, competiting processes, memory access and so on. Whereas running two different simulations on the same cpu nearly do not suffer from this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
efficiency, parallel computing
Large case parallel efficiency lakeat OpenFOAM Running, Solving & CFD 69 October 27, 2012 04:11
OpenFOAM with Inifiband & parallel efficiency LijieNPIC OpenFOAM 15 June 23, 2011 06:10
Parallel efficiency and speedup info lakeat OpenFOAM Running, Solving & CFD 2 August 31, 2009 12:05
Parelleling Efficiency kassiotis OpenFOAM 0 June 19, 2009 15:12
Parallel efficiency channel flow maka OpenFOAM Running, Solving & CFD 1 December 8, 2005 13:58
