mpt_read: failed: errno = 10054
Old   December 3, 2012, 17:23
Default mpt_read: failed: errno = 10054
mmdmov
mmdmov is on a distinguished road
I have a problem initializing my CFD problem in FLUENT. I open parallel FLUENT and load my case. Grid check is OK. When I want to initialize the problem I get this message:
MPI Application rank 5 exited before MPI_Finalize() with status -1073741819
999999 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
I'm also attaching a print screen showing the partition statistics.
Seems that parallel processing is not working properly. I can solve other problems on my computer in parallel. I was wondering if geometry/boundary conditions for this problem can cause this?
Due to the number of cells I have I can not initialize in the serial mode.
Any idea what's going wrong?
Very appreciated
mmdmov is offline   Reply With Quote
Old   March 5, 2013, 06:34
Kanarya is on a distinguished road
Hi mmdnov,
I have the similar problem did you manage to solve you problem?
thanks
Originally Posted by mmdmov View Post
Very appreciated
Kanarya is offline   Reply With Quote
Old   March 6, 2013, 15:07
mmdmov
There was nothing wrong with MPI or parallel. I had a problem setting up my problem. I found out that this message does not neccessarily mean that there is a problem with parallel processing.
fluent, mpi, parallel
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
DeardorffDiffStress turbulence model Zuixy OpenFOAM Running, Solving & CFD 0 November 14, 2011 09:44
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
