Enhanced Wall Treatment
Like Tree57Likes
Old   August 11, 2017, 14:35
Reviewer #2
randolph is on a distinguished road
Originally Posted by Far View Post
Enhanced wall treatment is not used by k-w SST model (see above), rather enhanced wall function (hybrid wall function is used).
Enhanced wall treatment is method to implement the enhanced wall function for the two layer model like K-epsilon model.
It uses the normal viscous sub layer (Y+= 1-5) and log law formulae (wall function with Y+ >30). Only difference is that it uses the blending function to make it useful in the region Y+ from 5-30 (buffer zone).
Enhanced wall treatment is method to implement the enhanced wall function for the two layer model like K-epsilon model ??
Shouldn't that Enhanced wall treatment is a method to make switch from the enhanced wall function (valid through all Y+) to the two layer model (one equation low K-epsilon and standard K-epsilon) when Y+ ~1??
randolph is offline   Reply With Quote
Old   August 14, 2017, 01:54
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Yes you are correct
Far is offline   Reply With Quote
Old   December 13, 2017, 13:37
Reviewer #2
regarding to the reply by far
2. K-omega based models were designed originally for the near wall region and therefore does not require the damping functions, hence the hybrid wall functions (blending of near wall and log law function) were implemented directly and same is true for SA model. You can find the details of latest work here for the k-omega and SA model with hybrid wall functions here
______________________
1. First K-omega based models were designed by Kolmogorov 1942. And I really double it is intended only for near-wall simulation
2. "Standard" k-omega (Wilcox 1988) does not require extra viscous modification to be able to predict mean velocity profile in boundary layer, which is not the case for standard K-epsilon
3. However, "Standard" k-omega (Wilcox 1988) will not accurately predict turbulence profile. As a results, a viscous modification (some people called it low Re corrections) is introduced by Wilcox (1991? I may be wrong on the time) in order to capture TKE peak etc. near the wall.
4. Don't get confused with wall function approach
I strongly recommend paper "A half century historical review of the k-w model " by Wilcox 1991.
wc34071209 and triimaran like this.
Old   January 8, 2018, 12:44
Yuehan
wc34071209 is on a distinguished road
How about the SST k-w formulation?
wc34071209 is offline   Reply With Quote
Old   January 8, 2018, 12:55
Reviewer #2
Check out the two papers (I do not remember anymore) by Menter 1993. But centrally, it formulated to behave like K-epsilon far from wall (although Omega is the variable), near the wall, it has the formula of the K-omega model (you can use the standard or the one with viscous extension)
Does realizable k-e model with enhanced wall treatment work for surface roughness? zyy95900 FLUENT 5 November 15, 2017 17:13
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 06:56
Wall treatment - RSM turbulence model djack STAR-CCM+ 1 September 12, 2012 11:51
Enhanced wall treatment with user-defined mu_t tstorm FLUENT 0 August 20, 2009 14:05
LES wall treatment Valerio FLUENT 0 April 26, 2008 08:12
