Question -> problem in transferring mesh into setup |
November 27, 2012, 04:52 |
Rep Power: 14 |
Hi guys, Actually I'm an amateur user.
I generate mesh for a 2d analysis of flow over a cylinder with 29000 nodes, but when I enter Setup the mesh totally changed and it becomes a simple deformed mesh with only 555 nodes !!!! Even I cant find the named selections I already entered, and they are chaned as well! the cylinder diameter is 0.016m and surprisingly when I design in a bigger scale (for example D= 1m) there is no problem anymore. thx in advanced Last edited by babak.mahjoub; November 27, 2012 at 05:10. |
November 28, 2012, 23:36 |
It could be a tolerance problem. If you say you don't have the issue when using a 'larger' mesh, just create the .msh file in units that don't give you a problem and then use the mesh--scale command to get your imported mesh into the correct units for your problem.
circular cylinder, cylinder mesh |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 20:55 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 09:52 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
