I am NOT getting right pressure at the air inlet in water column
Old   November 25, 2012, 00:15
Default I am NOT getting right pressure at the air inlet in water column
yes
kcfd is on a distinguished road
Problem Description:
Find the static pressure at the air inlet which is at the bottom in steady state condition for the container is completely filled with water initially. Kindly refer the attached picture for the problem understanding.
Simulated Condition:
1. Software Used: Ansys Fluent
Eulerian Multiphase Model: 2 Phase (Primary phase: water, secondary phase water with 0.0002mm dia)
2. Inlet Bounadry Condition: Air Velocity (very high velocity) with VOF 1; water velocity with 0 m/s
3. Outlet boundary condition: Pressure Outlet (0 gauge pressure and VOF 1 for secondary phase back flow)
4. Initial Condition: Entire domain is completely filled with water: VOF=1
5. Decent mesh size is there to capture the effect of velocity gradients
5. Solved by steady state and transient as well.
5. After solving, I obtained negative pressure when I did post processing with CFD post. But it should NOT be of any negative pressure at the inlet in reality.
Kindly help if there is any problem in my boundary condition set up or multiphase model selection. Thanks in advance.
Thanks& Regards, Raj
kcfd is offline   Reply With Quote
Old   November 25, 2012, 00:19
yes
Attached is the picture of the CFD domain for the problem description.
Old   November 27, 2012, 22:36
Default Hi!!
jobito_2012
jobito_2012 is on a distinguished road
mmm, I need to do the same case, can you send me the files please??
thansk a lot
jobito_2012 is offline   Reply With Quote
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 08:04
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
