boundary condition at the outlet of a gas turbine combustion chamber |
November 14, 2012, 08:04 |
Jim KIT
Rep Power: 14 |
Hello!
I'm currently trying to simulate a compressible flow without combustion through a combustion chamber for a gas turbine using Fluent. Therefore I need to determine the loss of pressure over the flame tube. My question is: Which boundary condition at the outlet of my combustion chamber should I use? The given parameters are: the mass flow, pressure and temperature at the end of my compressor/the inlet of my combustion chamber. I know that Fluent would accept the "Outflow"-boundary (in an incompressible case) to solve this problem without the use of any further information (e.g. velocity or pressure). If I try to use this kind of boundary in my compressible case, Fluent tells me to use the "Pressure Outlet"-boundary instead. The problem is, I don't know which pressure to set at the outlet, since the pressure loss over the chamber is the variable I'm trying to calculate. Is it somehow possible to use a Neumann-boundary condition (gradient of pressure equals zero) instead of using a constant value for the pressure? Does someone have an idea how to solve this? I would be very grateful! Greetings Jim |
November 14, 2012, 11:57 |
Lucky
Rep Power: 66 |
For the pressure outlet (which I agree is the correct boundary condition) you can enable the target mass flow rate option. This will keep the pressure as variable, the solver will iterate this to be the pressure needed to achieve a given mass flow rate across the boundary (which you do know). For compressible flows you need to know mass flow rate otherwise you do not have enough boundary conditions so I assume you already know it.
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
inlet and outlet boundary condition for turbomachinery solution | siamak1424 | OpenFOAM | 2 | August 15, 2009 12:14 |
boundary condition in combustion model | sambatra | OpenFOAM Running, Solving & CFD | 0 | April 30, 2009 03:16 |
Implications for heat transfer when outlet pressure boundary condition used | Blob | CFX | 2 | March 26, 2009 07:22 |
outlet boundary condition | Nina Schiepel | CFX | 2 | July 12, 2008 16:27 |
