Steady state Acoustic source contours
Old   November 5, 2012, 00:31
Default Steady state Acoustic source contours
Arun raj.S
arunraj is on a distinguished road
Hi all,
I am working on noise reduction in axial flow fan.. I am using FW-H acoustic model for noise prediction... It is an steady state analysis... But during post processing I am not able to find the acoustic source contours to understand from where the noise is actually generating... Is it possible to plot acoustic contours in steady state if I use Broadband noise model instead of FW-H.... It is really difficult to find how much contribution is there due to turbulence,tip vortex for fan noise generation with FW-H....
arunraj is offline   Reply With Quote
Old   November 5, 2012, 09:17
Question Error: Divergence detected in AMG solver: x-momentum.
Jaiganesh S
Jaiganesh S is on a distinguished road
Hi Mr. Arun raj,
I am doing Aeroacoustic analysis on aircraft wing using Ansys fluent. After 53 iterations, it getting error. I have mentioned that error below.
I have described about my case below.
Pressure based, Transient.
LES Model.
Velocity Inlet , pressure outlet.
Scheme- PISO, neighbor correction - 1, Pressure - standard, momentum - Bounded central differencing, Transient formulation- First order Implicit, non iterative time advancement.
URF for Pressure - 0.001, for Momentum - 0.004.
And also I used Outflow as outlet instead of Pressure outlet. I changed neighbour correction & under relaxation factor. These Changes are not working.
Grid quality details:
Max. cell squish= 9.23091e-001.
Max. aspect ratio = 3.22832e+002.
Kindly help me to solve this problem. I am waiting for your kind response.
Thank you.
Jaiganesh S is offline   Reply With Quote
Old   November 5, 2012, 23:48
Arun raj.S
I havenot worked in transient simulation... But this error seems to be related to your boundary condition...check your boundary condition properly...
Old   November 7, 2012, 07:23
Jaiganesh S
Thank you for your kind response. If i use hemi sphere domain instead of rectangular domain, will it solve x momentum error? what is the advantages of hemi sphere domain?
Kindly reply me. Thanks again.
Old   November 7, 2012, 07:30
Arun raj.S
I didnt anything related to your domain... It might be related to your mesh...check your mesh quality or bounday condition...I am doing acoustic analyis of axial flow fan...But I am not using any hemispherical domain...
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
