Time averaged velocity in turbulent pipe flow
Old   October 31, 2012, 14:58
Default Time averaged velocity in turbulent pipe flow
tsero is on a distinguished road
Hello everyone,
I have solved a 3D turbulent pipe flow model in FLUENT and I want to plot the time averaged velocity throughout the pipe. I am defining the Flow in=8kg/s and according to the pipe diameter the time averaged velocity should be around 0.35m/s. (I dont know if I should refer to that as mean velocity)
I tried to plot the Velocity Magnitude but that scale is the sum of the squares of the velocity components U=sqrt(Vx^2+Vy^2+Vz^2)=0.73m/s which is not what I am looking for.
When I try to export a plot for Tecplot there are many different velocities I can plot but none of them is the one I need.
Thank you very much,
George
tsero is offline   Reply With Quote
Old   November 2, 2012, 04:19
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
U should be a good estimate of what you are looking for, since the velocity perpendicular to the pipe wall is much smaller than the parallel component. Maybe you miscalculated the average value? Give us all relevant numbers to check that.
RodriguezFatz is offline   Reply With Quote
mean velocity, time averaged velocity, turbulence, turbulent flow
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 06:35
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 04:37
CFD Analysis of 2D Turbulent Pipe Flow erucalavera FLUENT 1 May 30, 2012 06:22
SimpleFoam pipe flow velocity blowup gzink OpenFOAM Running, Solving & CFD 0 June 9, 2006 17:52
