Error: Divergence detected in AMG solver: x-momentum
Like Tree10Likes
Old   September 26, 2013, 06:50
vidyanand
Vidyanand Kesti is on a distinguished road
if you rae using FLUENT can you convert to ploy and try may be you can avoiad this
Mesh-ployhydrel-convert domain
or smooth and swap
Vidyanand Kesti is offline   Reply With Quote
Old   September 26, 2013, 10:09
Vjoess
dinesh is on a distinguished road
Originally Posted by ghost82 View Post
You must assign X as the axisymmetric axis.
Daniele
thank-you sir
Is there a method where i can change my Y axis to X axis. So that i dont have to make it again? Even if it is possible in workbench please let me know?
dinesh is offline   Reply With Quote
Old   September 26, 2013, 10:19
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Originally Posted by dinesh View Post
thank-you sir
I think you have to go back to pre processing and rotate/translate geometry+mesh.
Daniele
ghost82 is offline   Reply With Quote
Old   September 29, 2013, 16:29
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Originally Posted by niloogh View Post
hi Daniele
is taking x axis as axisymmetric needed in 3D too???
Hi Friend
As far as I know, there's no necessity for 3d geometry to define x axis as axisymmetric B.C.
Good luck
Regard yours
A CFD free user is offline   Reply With Quote
Old   September 30, 2013, 02:06
Default need help
  #25
Andika
ryujibando is on a distinguished road
Hello my name is aan. Now I'm doing project about combustion zone in secondary reformer of ammonia plant. Can anyone check mesh generated in my project? I really appreciate if there is someone who would like to discuss with me.
Best regards,
AAN
ryujibando is offline   Reply With Quote
Old   March 28, 2014, 11:04
samir
samir_cfd is on a distinguished road
Send a message via MSN to samir_cfd Send a message via Skype™ to samir_cfd
Good day
I have a problem when I am simulate unsteady flow around a propeller, divergence detected in amg solver. x momentum, I reduce the URF but is the same problem
samir_cfd is offline   Reply With Quote
Old   March 29, 2014, 12:33
Nick Prendergast
neprendo is on a distinguished road
Its probably an issue with your boundary conditions and/or mesh then. Double check your BCs, refine your mesh and put the URFs back to the defaults. The default URFs with make your solution converge quicker.
Nick
neprendo is offline   Reply With Quote
Old   March 30, 2014, 23:15
Abhijith Mohan
abhijithmohan is on a distinguished road
try changing the mesh and relaxation factor
abhijithmohan is offline   Reply With Quote
Old   April 9, 2014, 04:44
chrischensong is on a distinguished road
hi dear
my problem was related to the periodic boundaries.after changing some things in gambit ;i had solved my problem.if your problem has periodic boundaries i,ll explan it in details for you.
Hi niloogh,
I got a similar problem now. I added a udf velocity profile at the inlet of a pipe and the domain is only quarter of real geometry with periodic boundary condition. I have tried all the ways that mentioned above but the error message still comes out every time "Divergence detected in AMG solver". Could you tell me that how did you solve your problem with the periodic bcs?
Thanks
Chris
Triality likes this.
chrischensong is offline   Reply With Quote
Old   April 16, 2014, 19:44
Shravani
shrav is on a distinguished road
hi dear
I have periodic boundaries in my model and i am facing the same error - divergence in the AMG solver x momentum. Can you plz explain how u solved ur problem
shrav is offline   Reply With Quote
Old   May 27, 2014, 08:01
Noorul Huda
noorul is on a distinguished road
Daniele
how to set the direction of axis symmetric flow?
noorul is offline   Reply With Quote
Old   May 27, 2014, 09:43
ghost82's Avatar
Rick
It must be done in pre processing
Old   November 29, 2015, 05:14
Siva
Triality is on a distinguished road
Hi Marion , im facing the same problem . Mine calculation popped out error after run a certain number of iterations, any solution to it ? Thanks in advance .
Triality is offline   Reply With Quote
Old   April 13, 2016, 11:10
靳亚楠
yanan-0124 is on a distinguished road
Originally Posted by cfd seeker View Post
Reduce the under relaxation factors
hello ,i am doing the water injection into the air.And i am faced with the same problem ( Divergence detected in AMG solver: x-momentum ).Because my mesh is 3-D, i am confused about the symmetry .
thank you in advance !!
yanan-0124 is offline   Reply With Quote
fluent, vof, vof model
divergence detected in AMG solver: momentum sudhakar FLUENT 41 January 23, 2024 04:56
Divergence detected in AMG solver msatrustegui FLUENT 16 March 20, 2017 10:20
divergence detected in AMG solver: temperature mashinsazi FLUENT 8 December 9, 2014 10:18
Divergence detected in AMG solver Musa FLUENT 3 March 4, 2012 13:40
AMG solver _divergence detected Shamoon FLUENT 6 March 11, 2009 08:59
