October 26, 2012, 14:12 |
Tutorial Meshing Problem
Rep Power: 14 |
I am new to Fluent, I am a former user of StarCCM+, and am having some issues with the 1st and 2nd tutorials. When I create the mesh as described in tutorial 1 an error appears: "The mesh exporter failed during translation. Please send your data to your support provider". I had success with the second tutorial until I started doing post processing and received the same error after I updated Workbench. I have contacted ANSYS and have not received any response yet. I believe this is because I am using an academic license and am not eligible for tech support. I have also searched and have been successful at finding the same problem but am still unable to resolve my issue following that users guidelines. The mesh appears on the screen but does not export to Workbench. I am using ANSYS 14.Any help would be much appreciated.
October 27, 2012, 09:25 |
Rep Power: 14 |
Yes, I can get some pictures of what is going on shortly.
October 27, 2012, 10:36 |
Rep Power: 14 |
Here are the pictures of what is going on. The second tutorial has multiple errors mainly because of the additional design points.
October 27, 2012, 15:29 |
Rep Power: 14 |
I have closed, reopened, and then started from scratch to no avail. I'm thinking I should just move on.
[ICEM] Problem with meshing half NACA0009 in 3D | Eizo | ANSYS Meshing & Geometry | 30 | February 17, 2013 03:40 |
[snappyHexMesh] snappyHexMesh: problem meshing baffle (surface with zero thickness) | julien.decharentenay | OpenFOAM Meshing & Mesh Conversion | 7 | June 16, 2012 09:12 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 01:35 |
problem meshing with low y+ | cesco | FLUENT | 8 | February 23, 2009 06:12 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 10:57 |
