FLuent simulation of taylor couette flow of concentric cylinder geometry. |
October 29, 2012, 13:32 |
#41 | |
Rick
Rep Power: 27 |
see this link for link faces: http://202.118.250.111:8080/fluent/G...ce_link_unlink Yes, select reverse orientation, since arrows are in opposite directions. |
November 2, 2012, 14:42 |
#42 |
rshbhb
Rep Power: 14 |
Dear Sir,
You had once mentioned that TECPLOT could be used to get the attached picture? 1.could you explain me how to do it in TECPLOT (as I am not getting both contours and velocity vector in one picture.) I have simulated the results for different ang. vel. & geometries but only for 10,30 and 45 deg meshs. 1.But for nicer interpretation I want to know the particle pathline for the complete 360 degs or any other way so that I can analyze that its WVF or TVF and stuff like that......... is there anyway, that I can do it ? |
November 2, 2012, 17:00 |
#43 | |
November 3, 2012, 05:53 |
#44 |
rshbhb
Rep Power: 14 |
Yes Sir the mesh file were useful to me, as it provided me an idea of how many nodes to create in the different sections.
I din't simulate the flow in our mesh file as I wasn't able to convert the top and bottom faces into periodic boundaries in FLUENT solver 6.3.26 . THank you !! Referring to my last post's image, is it possible to get the black colored vectors in the vel. contours in tecplot ? ANd how can I deduce that at a particular flow rate the flow is WVF or TVF ? |
November 3, 2012, 06:45 |
#45 | |
Yes black vectors and velocity contours can be displayed simultaneously in Techplot. What is WVF or TVF? Last edited by Far; November 3, 2012 at 11:26. |
November 3, 2012, 07:26 |
#46 | |
rshbhb
Rep Power: 14 |
TVF- Taylor Vortex FLow WVF comes after TVF at higher reynolds number. Please let me know the procedure for plotting it in TECPLOT too !! |
November 3, 2012, 09:07 |
#47 |
I have specially installed fluent 6.3.26 to illustrate how to make the translational periodicity in Fluent (or rotational periodicity as you prefer). Keep in mind ICEM does not allow me to add both.
Youtube link http://www.youtube.com/watch?v=URpeH...ature=youtu.be |
November 4, 2012, 06:54 |
#49 |
Rick
Rep Power: 27 |
Sorry for delay, I was out for a couple of days;
I think this can be evaluated by look at the pathlines; look at the attached picture I found on google to identify different flows. Daniele |
November 4, 2012, 07:00 |
#50 | |
Rick
Rep Power: 27 |
You can use also tecplot, with the "slice" feature; on the slice window option choose to plot vectors. However this is simpler with fluent itself or cfd-post. Daniele |
August 28, 2013, 12:53 |
#51 |
behzad
Rep Power: 13 |
September 13, 2013, 11:10 |
#52 |
someone indicated that link for dropbox files is not working : Post # 25. Here is new link:
https://dl.dropboxusercontent.com/u/...ute_taylor.rar |
September 12, 2014, 02:10 |
hi rishabh
#53 |
rahul kumar
Rep Power: 12 |
if you want to know your flow near the surface wall of your domain then you can use " k-episilon" and if you want to know far away from the surface wall then use "k-omega
November 5, 2014, 20:07 |
#54 |
Rachel
Rep Power: 12 |
I have a question, sorry if it is stupid.
How did you increase the number of divisions in the radial direction for the mesh? I have a school project now where we are trying to model this flow, but we are having extreme problems creating a regular mesh which has enough divisions in the radial direction (from the inner wall to the outer wall). Any help you could provide would be very appreciated. Again, sorry if this is a stupid question. |
Simulation of cylinder aligned in the flow direction using k-e model | Eliasjal | FLUENT | 2 | June 13, 2012 09:00 |
Simulation of steam (CO2 and Water vapor mixture) flow through nozzle using Fluent. | Jimmy | FLUENT | 0 | March 2, 2011 13:30 |
Simulation Flow Around cylinder 3D | Jwolf | CFX | 19 | November 25, 2009 15:21 |
Compressible flow simulation using FLUENT | arun | Main CFD Forum | 0 | February 16, 2004 16:44 |
Simulation of the Flow past a circular cylinder using STAR-CD | M. S. GUEROUACHE | Main CFD Forum | 0 | October 1, 1998 11:51 |
