Need help : natural convection in inclined convergent channel |
October 21, 2012, 13:08 |
hello all, first of all, sorry for my bad english
im still newbie here and hope to get some help i have some problem on inclined convergent channel system. The system has 2 inclined wall with same temperatur (i set 332K for both wall). The bottom & top temperatur is set to 300K. The bottom side is inlet and the top side is outlet. What boundary condition should i choose for top & bottom? is that true if i set the top & bottom side of system is set to pressure outlet & pressure inlet? In material panel, i set density properties to boussinesq, should i change its value (default value = 0)? When i have convergence problem, i try to change the under relaxation factor, i decrease it gradually until the residual almost constant. Is there any limit value in decreasing uder relaxation factor? Any help would be very useful to me, thanks |
October 21, 2012, 13:31 |
SSL
Rep Power: 15 |
1- Don't change fluent default values without information
2- You should define that density value. Set the density. Zero is incorrect. 3- If you have a natural convection in a closed box, all boundary conditions should be as wall. 4- Natural convection is highly sensitive to mesh size. change it to get a good result. |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 10:26 |
modeling natural convection in tilted channel | Luis | FLUENT | 0 | April 27, 2008 16:56 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 05:58 |
Approximate Mixing due to Natural Convection | Greg Perkins | Main CFD Forum | 0 | February 12, 2003 19:43 |
natural convection in a sealed enclosure | James | Main CFD Forum | 4 | April 2, 2001 16:48 |
