Musango Lungu
Rep Power: 14 ![]() |
I am running a case with 4 udfs. I want to store and monitor 3 of the udfs using the UDM function. However the UDMs appear as udm0,udm1 and udm2. How do I change the names of the UDMs and how do I ensure which UDM stands for which udf. Please help!
#2 | |
Ehsan Asgari
Rep Power: 18 ![]() |
and also you can change UDM name by the following command, void Set_User_Memory_Name(int i,char *name) which "i" is the index of UDM, for example 0 and "name" is what you wish to assign as name to your UDM. If you desire to load more than one UDF, you may reserve UDM for each one of UDF. Take a look at UDF manual, it has explained things well. Goodluck |
Trouble setting user scalar and user memory names | tstorm | FLUENT | 6 | November 23, 2022 03:58 |
Creating new user defined material | Vidya | FLUENT | 4 | August 26, 2013 09:26 |
user defined sourcen term | xck1986 | CFX | 1 | July 8, 2010 08:35 |
user defined turbulence model | manuutin | STAR-CD | 5 | October 14, 2009 05:29 |
Gradient of a User defined Variable | Ramadas | CFX | 2 | August 21, 2007 09:19 |
