Cooling- Heat transfer model
Old   October 15, 2012, 13:41
Default Cooling- Heat transfer model
Markat is on a distinguished road
Hello everybody,
i'm glad to have joined the CFD Online community. I am a new ANSYS Fluent and generally CFD user (though I have relatively much experience in structural models). I'm trying to build the following CFD Model as part of my bachelor thesis: A free elliptical solid rigid body (2D Model) with T=700K is being cooled through convection and radiation. The fluid (environment) is air and the boundary conditions are velocity inlet (x: 2m/s, y=0, T=300K) and pressure outlet (gauge pressure=0, T=300K). The flow is turbulent due to Reynolds number for L= string of ellipse= 1m (I have used a k-e model). As radiation model I have used the DO model. Through this model I would like to calculate:
1. The cooling rate of the elliptical body in K/s
2.The temperature gradient in the body
First I have built a flow model with energy equation off, which has converged.Then I tried to calculate the convection model. Unfortunately I couldnīt find a way to define the temperature of the body so that it wouldn't be constant (I tried to define the body's wall temperature, which apparently remains constant during the calculation of the solution).
What are your suggestions?
What strategies should I follow to build my model?
Do you have further suggestions and recommendation for a new user like me?
Thank you in advance.
P.S. I have attached a .jpg of the model
Markat is offline   Reply With Quote
Old   October 16, 2012, 15:31
  1. Could you please help me defining the boundary conditions in the conjugate heat transfer problem (without taking the radiation into account). I have red older threads about wall and wall-shadow but in my model both the wall and the wall shadow are aluminium. I wasn't able to turn one of them to fluid. I have already turned the 2 parts into one part with 2 bodies so that I do not have to use contacts.
  2. I would like also to mention that when I try to solve k-e Modell (a this point energy equation off only flow model) the solution converged and the flow was laminar.When I try to solve a laminar model the solution does not corverge. Do you have any idea why?
Old   October 17, 2012, 14:09
Does anybody have any suggestion? Should I preferably mesh the solid or not?
Old   October 18, 2012, 18:58
Has anyone any idea?
Old   October 20, 2012, 14:23
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
Hi.
Boundary conditions are OK. Why can't get answer?
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   February 8, 2013, 01:45
achal
achal is on a distinguished road
hi , i am also working on a similar kind of problem. I was wondering if you could help me.
Problem Description : An iron brick is to be cooled by the use of
water jet, this would include convection from the top surface of brick
and conduction within the brick.
Is that what we call a conjugate heat transfer ?
Can it modelled with out the use of UDF ?
How do I model this, because there is no temperature change observed ?
Any sort of help would highly be appreciated.
achal is offline   Reply With Quote
Old   February 8, 2013, 09:55
SSL
msaeedsadeghi is on a distinguished road
There is no need of udf. Fluent can model it by default settings. Think of boundary conditions. There would be fundamental problems.
msaeedsadeghi is offline   Reply With Quote
Old   February 8, 2013, 11:08
achal
I tried the problem a couple of hours earlier, there is no need of udf.
Also, to give the initial value to the hot brick, we will have to use Patch option ?
and in the post processing, can I get a temperature profile at a particular time of a particular cross section ?
Regards
Achal
Old   February 8, 2013, 19:45
What temperature does the brick have? In high temperatures you should also consider and model radiation. Patching is goof way to define an initial temperature, but only if you mesh your brick. Otherwise you have to define manually an appropriate region to define the initial temperature.
Did you use shell conduction or did you mesh your solid?
I would also like to ask, if does have the same effect giving an initial temperature (by solution initialization) and patching a temperature?
Old   February 9, 2013, 01:22
achal
temperature is not high to consider radiation. no, i am not using shell conduction as i have brick a solid entity.
patching and solution initialization are 2 different thins.... it does not have the same effect
thanks
Achal
Forced heat transfer model srinivasa Main CFD Forum 2 September 15, 2011 02:24
Modelling the heat transfer during compression and cooling of natural gas pano Main CFD Forum 0 December 10, 2010 16:53
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 09:54
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
is there heat transfer option in multiphase model gayaz FLUENT 1 July 16, 2003 12:13
