Turbulent Boundary condition, viscosity ratio and length scale
Like Tree22Likes
Old   October 30, 2012, 11:03
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by Bollonga View Post
Thanks a lot. How big are the files?
I've managed to export your mesh in 2D, but it gives error when importing it in parallel mode. An error message says:
Build Grid: Aborted due to critical error.
There are also several messages in the command window saying:
4:WARNING: cell id 28340 of thread 24 has NULL face pointer 3.
Primitive Error at node 4: Build Grid: Aborted due to critical error.
Which can be the reason?
This is because of meshing error which is not acceptable to fluent. Did you turn off the solid and vorfn blocks before exporting the mesh?
Far is offline   Reply With Quote
Old   October 30, 2012, 14:21
Francisco
Bollonga is on a distinguished road
How can I do that?
Bollonga is offline   Reply With Quote
Old   October 30, 2012, 14:27
Far
Sijal
But there should not be error in mesh as I have used it for simulation in Fluent and shown in this thread.
Old   December 12, 2012, 04:51
Default Icem problem
  #64
Francisco
Hello everybody,
In this month I've made some progress with the flat plate, the key was using k-epsilon Realizable with enhanced wall treatment, and I got CD and CL way more similar to the literature ones.
Now I'm learning to use Icem (v13) because I need an optimal mesh to do the 3D case.
However, I've encountered a problem when exporting my mesh to fluent. It's a 2D hex mesh with a blocking strategy. When I try to open it in Fluent it gives this message:
FLUENT reveiced fatal signal (ACCESS VIOLATION)
I've read that I should use serial processor instead of paralell, but the message is still there. I've made some reading in the internet and read that all edges must be related to curves. I have some interior edges that I don't know to which curve relate.
I upload the geometry and icem files in the following link, but I would like to know how to solve that. Thanks in advance.
https://dl.dropbox.com/u/6986695/PS_2D_Icem.zip
Old   December 12, 2012, 14:54
Francisco
Now I have solved the previous problem, it was due to some mesh setting I was skipping.
But now I'm facing new problems. I've done my 2D hex mesh, I export it to fluent and when I try to read it it gives many messages saying:
Skipping zone (not referenced by grid)
So I get all zones deleted. I've tried with the fix option in Icem, and it's supposed to have fixed many things, but I'm still getting the same problem. I've made a search at the forum but got no useful tip.
Your help would be much appreciated.
Old   December 13, 2012, 03:53
Francisco
I've solves those problems with the help of people in the geometry and meshing forum. Thanks anyway! Now I'm gonna try the 3D simulation, I'll inform about my results!
Old   January 29, 2013, 04:11
Default Flow around 3D flat plate of large span
  #67
Francisco
Hi everybody!
Here I am again stuck with the 3D case of the flat plate.
I'm just trying to reproduce the air flow over a 0.15m flat plate inclined 70บ. Flow speed is 15 m/s.
I've used k-epsilon Realizable with enhanced wall treatment and k-omega SST but both have failed. Simulation starts slowly (adaptive time-step from 1e-5 to 1e-6 s) but converging until it reaches some point in which it diverges sharply (see picture). It reaches Turbulent viscosity ratio limitation to 1e5 in too many cells.
I've remeshed the geometry but I always get similar results.
I know I can play with the material viscosity, so should I reduce the speed and viscosity to maintain the same Reynolds number and avoid this limitation? Is it an appropiate approach?
Any suggestion is highly appreciated!
Old   January 29, 2013, 04:36
SSL
msaeedsadeghi is on a distinguished road
The only problem is with the mesh. Try to make a better mesh.
msaeedsadeghi is offline   Reply With Quote
Old   January 29, 2013, 05:06
Francisco
Does the mesh have to be much finer in all the wake? That would make the case very expensive.
I've observed that turbulent viscosity ratio limitation appears near the corners of the plate and then it's transported to the rest of the wake.
Maybe if I improve the mesh just there it won't reach the limitation?
Old   January 29, 2013, 05:14
SSL
Try to make an structured mesh if possible, else you should make a finer mesh.
Old   January 29, 2013, 05:32
Francisco
Sure, I'm using an hexa-mesh. I'm gonna refine the o-grid block around the plate and the areas near the body. I'll share my results here.
Old   January 29, 2013, 12:04
Francisco
Besides using a finer mesh, for a turbulent intensity of 5% and 15 m/s in the inlet, which turbulent length scale should I use? I had good results in 2D with k-ep realizable and turbulent length scale of 0.05 m but that setup was giving problems for 3D.
Old   January 31, 2013, 01:39
Aditya Pandare
aditya.pandare is on a distinguished road
I suggest you go for a y+ of under 10 and then use the enhanced wall function.
I agree to the suggestion of using icem cfd and getting a structured mesh (wont take more than 2 days to make this, even if u start from scratch)
I also suggest you try a still smaller timestep
if it still doesnt resolve the issue, go for severe underrelaxation for the first few timesteps.
aditya.pandare is offline   Reply With Quote
Old   February 9, 2013, 05:08
Francisco
I already have an hexa-mesh and first layer thickness of the o-grid block is pretty small so I guess I'll get y+<10.
I'm gonna try a smaller timestep using the adaptive timestep option, say from 1e-3 to 1e-8 s with 10 as maximum timestep factor and 0.1 as the minimum.
However, I would like to know which is the optimum solver configuration, I'm using this one:
Pressure-velocity coupling: PISO (skewness correction =1, neighbor correction =1, skewness-neighbor correction enabled)
Spatial discretization:
Gradient: Least Squares cell based
Pressure: PRESTO!
Momentum: Second Order Upwind
Turbulent Kinetic Energy: First Order Upwind (I'll change it to 2nd order later on)
Turbulent Dissipation rate: First Order Upwind (I'll change it to 2nd order later on)
Transient Formulation: First Order Upwind (in order to use adaptive timestep, I might change it to 2nd order when I'll get a constant timestep)
In case this doesn't work I'll change under relaxation factors as suggested by Aditya.
The question is for how many iterations should I maintain the reduced under-relaxation factors? And which values should I use?
Thanks a lot guys!
Old   February 9, 2013, 05:22
Far
Sijal
You need good mesh in wake region. did you make the domain extend study?
Old   February 9, 2013, 05:36
Francisco
I did it for the 2D case, 13 times the plate chord downstream was appropiate .
To begin I've used a 1e-8 s timestep (adaptive timestep), 50 iterations for timestep and turbulent viscosity under-relaxation factor of 0.5 (the rest of them as default)
TVR limitation appears from the very first iteration. Divergence appears at only 7 iterations.
I'm initializing the solution from inlet (U=15m/s, TI=5% and TLS=0.05m).
I guess it might be due to bad initial condition... but I'm not sure. Any ideas?
Old   February 9, 2013, 05:42
Far
Sijal
13 chords downstream with 70 deg inclination? I guess it is not enough...
Can you show velocity and pressure contours?
mrenergy likes this.
Old   February 9, 2013, 05:55
Francisco
I've just checked the former 2D simulation an the domain extend is 30 times chord downstream. I attach static pressure and velocity magnitude images.
I guess I need a similar wake extend in the 3D case, but is initialization from inlet a correct approach?
File Type: jpg PS_2D_08_11_Iu5_L0.05-0.945_Pstatic.jpg (62.7 KB, 11 views)
File Type: jpg PS_2D_08_11_Iu5_L0.05-2-0.945_Vmagnitude.jpg (63.2 KB, 12 views)
Old   February 9, 2013, 09:42
Far
Sijal
results look good but convergence plot not. Init from inlet is ok.
Old   February 11, 2013, 00:04
Aditya Pandare
reduce the relaxation by an order of magnitude at the most.
use it until your residuals start decreasing (time-step wise).
this is a question of both judgement and trial-error; so try a few times; generally, using the reduced under-relaxn for a few time-steps after the reducing trend begins is sufficient.
3d 2d, flat plate, turbulence models, viscosity limitation
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Turbulent viscosity ratio limited to 1.10^5 in boundary layer ingestion loicflouriot FLUENT 0 May 27, 2012 08:31
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
