October 12, 2012, 01:33 |
heat transfer inside a tube
Ajay Khaitan
To simulate the heat transfer for fluid flow in a tube, is a 3-D mesh required or would a 2-D mesh do?
October 12, 2012, 22:35 |
Ehsan Asgari
Rep Power: 18 |
If you have a simple circular pipe with uni-directional velocity profile, you can easily implement a 2-D geometry with "axis" B.C. type instead of a 3-D case.
October 13, 2012, 14:46 |
misagh
Rep Power: 14 |
hi
it is also dependent to your b.c geometry ... for example for conjugate heat transfer(conduction+convection) is SHOULD be 3.d since in 2.d there is not the b.c ''shell conduction'' in fluent. Last edited by misagh; October 14, 2012 at 15:37. |
October 13, 2012, 21:57 |
Rep Power: 14 |
If your flow is axisymmetric, then you can model the flow as 2 D
radiation heat transfer | GeHa | FLUENT | 1 | September 5, 2012 14:56 |
Problems involved heat transfer inside a particle and its thermal degradation | zhangr | STAR-CCM+ | 2 | August 25, 2011 06:59 |
Flow in a tube with heat transfer. | masb | OpenFOAM | 6 | June 29, 2011 06:56 |
Heat transfer in helically tube | nicolas | FLUENT | 1 | September 17, 2007 10:45 |
heat transfer inside adiabatic enclosures | varghese | FLUENT | 1 | January 30, 2002 04:21 |
