Supersonic Inlet for a Compressible Flow in a Nozzle
Old   October 10, 2012, 12:56
Default Supersonic Inlet for a Compressible Flow in a Nozzle
Daco is on a distinguished road
Hi!
I am trying to solve a compressible flow in a diverging converging problem.
I am using the mesh given in the cornell problem:
https://confluence.cornell.edu/display/SIMULATION/Fluent+-+Compressible+Flow+in+a+Nozzle
The difference from the cornell tutorial is that I want to solve it for a Supersonic flow at the inlet. as if it was a diffuser.
the area ratio A_inlet/A_t=3.5
I use Pressure Inlet with: P_total=101325, P_static=3733.8, T_total=765.2
which are the A/A* values for a the 1D isentropic problem.
for the outlet I use Pressure Outlet with:P_static=3733.8, T_total=765.2
I am trying to reach supersonic inlet to sonic throat to supersonic outlet.
I am solving it in steady state.
the problem is that the program completely diverges after a few iterations and keeps on diverging. I tried refining the mesh with "Adapt" tool but it doesn't seem to help.
What am I doing wrong?
I have searched all over and I don't seem to find info about how to solve a problem with a Supersonic Inlet. maybe the problem is in the steady state?
thanks!
Daco is offline   Reply With Quote
Old   October 10, 2012, 16:14
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
Which solver diverges first? That may be a hint. I've had divergence problems before and if I under-relax the solver that diverges first a little bit (~0.05 to ~0.1 change) it helps.
NormalVector is offline   Reply With Quote
Old   October 10, 2012, 16:28
Thanks for the tip. I'll be sure to try it.
I'll post what happens when I get to it.
Old   October 10, 2012, 17:08
NormalVector
Sure. It may take more a more aggressive relaxation effort than a 0.1 change so you can try that as well.
Old   October 12, 2012, 12:19
wissou22 is on a distinguished road
hi,
i want to put sinusoidal pressure inlet, is it possible in fluent?
wissou22 is offline   Reply With Quote
Old   October 14, 2012, 05:16
to your question wissou22, yes you can do it in fluent.
One way I know of is by UDF (User Defined function).
check out Tutorial 4:Modeling Transient Compressible Flow in the FLUENT 12.0 tutorial guide. they do exactly what you want, only they do it at the outlet.
NormalVector, I am solving the problem in a density-based solver and I don't see an option for inputing relaxation parameters anywhere..
also at that subjet, If I'm solving a problem that should be supersonic (or sonic) in all the domain, What is the best solver to use?
I used the density solver with its default settings:
Formulation: Implicit
Flux Type: Roe-FDS
Gradient: Least Squares Cell Based
Flow: Second Order Upwind
Are those settings good for supersonic flows?
Thanks
Old   November 7, 2012, 22:43
Yao, Cheng
slaon is on a distinguished road
Hi, Daco.
I'm doing a similar work as you did. :-)
My simulation begins with 1st order Upwind scheme. It works well.
But when I use 2nd order Upwind scheme, it diverged. Some people tell me, there isn't flux limiter in FLUENT. So it must diverge because of the numerical oscillation when using the 2nd upwind scheme. However, I don't how to get a 2nd order result in FLUENT.
And they suggest CFX to me, since it has resolution scheme. Maybe the problem can be solved in CFX.
The geometry I used in my work is similar to Anderson's. And his report is available as follows.
http://ntrs.nasa.gov/archive/nasa/ca...1970018205.pdf
http://ntrs.nasa.gov/archive/nasa/ca...1971017509.pdf
If you get some improvement, please let me known: slaonslaon@gmail.com . Thanks. :-)
Originally Posted by Daco View Post
Hi!
thanks!
slaon is offline   Reply With Quote
Old   November 8, 2012, 00:51
Well, I have a partial answer because I left this project.
I found out that for the implicit solution method the program is completely divergent. When I tried Explicit it actually worked without exploding but it also didn't converge and the error monitor always moved around 10^-1.
So I suggest using the explicit method for supersonic inlets.
Next, I think I had some problems with my geometry so I think some of my problems were caused by that. I reached a conclusion that because the geometry begins at the inlet without any straight geometry with a uniform flow before it, when a shock wave started to form at the inlet opening the program couldn't converge. so here I suggest when dealing with a con-div-nozzle use an initial straight geometry before the walls start to converge. Maybe even create a mesh outside the nozzle to see if a shock wave forms on the lips of the opening.
Like I said I left this project and didn't reach a good converged solution. All I said here is only my conclusions while working so don't take it as a 100% truth.
Isn't it silly that its very hard to solve a very simple case in a large commercial CFD program like FLUENT? I really don't get it..
Thanks!
Old   November 8, 2012, 04:34
Yao, Cheng
Thank you for your reply and suggestion.
Difficulty running an inviscid compressible nozzle flow using OpenFOAM rbozinoski OpenFOAM Running, Solving & CFD 11 December 29, 2015 08:19
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
Modeling Laval nozzle, subsonic flow to supersonic Bloshchitsyn Vladimir CFX 2 June 18, 2007 06:18
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
