FSI: How to transfer static pressure from fluent to ANSYS
Old   October 9, 2012, 14:37
Default FSI: How to transfer static pressure from fluent to ANSYS
Sean (J.X.) Shi
momo_sjx is on a distinguished road
I am learning to use two-way FSI ANSYS/Fluent to simulate the Wing flap.
When I use one-way FSI, I use import load/pressure in ANSYS, it works fine. The static pressure is correctly imported.
But when I use two-way FSI, I use fluid solid interface in ANSYS, it can not work. Following the tutorial, I change the reference pressure to 0 in Fluent. But yet useless. For the same flow, the stress show in one-way FSI is totally different from two-way FSI.
Someone can help me?
Thanks a lot.
momo_sjx is offline   Reply With Quote
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Exporting Pressure data from FLUENT to ANSYS Whats_in_a_name FLUENT 7 September 3, 2017 04:09
ANSYS MFX FSI load transfer method peiji1984 ANSYS 0 May 21, 2012 04:05
how to transfer a mesh from workbentch into fluent using ansys 12 0617157 ANSYS 2 March 21, 2010 15:07
a problem in calculating pressure drop in Fluent? yu chun FLUENT 1 May 18, 2004 04:40
