Fluent airfoil help
Like Tree1Likes
Old   September 30, 2012, 23:51
Question Fluent airfoil help
Jonathan
Archer_CFD is on a distinguished road
Hello everyone,
I'm new to CFD and need some help modelling an airfoil in Fluent.
I'm modelling both NACA 0012 and NACA 0015 airfoils in 2D. My lift coefficients are very close to experimental values, but drag coefficients are too small (by a factor of about 10).
I am using a C-grid mesh of 40,000 elements and a Reynolds value on the order of 200,000. Currently I am using the viscous-inviscid model and I assume that this is the source of the error.
I have played around with Spalart-Allmaras and k-omega models but I don't know what to do and can not get these to converge.
Any advice on constructing a more accurate simulation would be greatly appreciate.
Thank you.
Archer_CFD is offline   Reply With Quote
Old   October 1, 2012, 05:53
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by Archer_CFD View Post
Hello everyone,
Thank you.
You have to consider viscous effects to get an realistic value for Cd. But first you must calculate Re number to make sure whether your flow is laminar or turbulent. You'd better take a look at Fluent tutorial, it contains a very good example about the flow around the airfoil.
Bests.
syavash is offline   Reply With Quote
Old   October 1, 2012, 23:14
Jonathan
Thank you for your response.
Do you mean the "Modelling External Compressible Flow" tutorial? If so, then I have been trying to use that one as a guide. However, because it uses compressible flow and I am not, because of my lack of understanding of the software I don't know what I need to change.
Currently the Reynolds values for my simulations are around the 100,000 mark and all less than 200,000. Later, once I get these simulations working, I will be modelling Reynolds values on the order of 1,000,000.
My understanding is that, for airfoils, values less than 500,000 indicate laminar flow.
I have tried using the Viscous-Laminar model in fluent, but it did not converge.
I am beginning to have more success with the Spalart-Allmaras model, but now my lift values are 10% too low and drag 45% too high.
I was wondering if anyone knew of a reliable model for Re=200,000 airfoils in fluent that I could basically copy and then modify?
My main aim is to compare maximum L/D ratios for a selection of aerofoils and find the best one. However, with my current model, the AoA for the maximum L/D is out by 2 or 3 degrees.
Thanks again.
Old   October 2, 2012, 00:51
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
can you share a picture of your mesh ??
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   October 2, 2012, 05:04
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi Jonathan,
I am no airfoil expert, but here are some general thoughts:
1) If you choose "inviscit model", you switch off the natural "no-slip" boundary condition that occours at real (surface) boundaries. Your fluid's velocity isn't set to zero at the airfoil any longer. Thus, the fluid slips at the airfoil boundary without creating drag. I guess the lift is produced by pressure effects (?!) which can be reproduced even by this strongly unphysical boundary condition.
This would be in good agreement with your observation.
2) If your flow is actually laminar, you should not use any turbulence model at all - so take "viscous - laminar". If your simulation does not converge, it could be a meshing problem or a numerical problem (or ...). This is, what Diamondx indicates by asking you for your mesh. Also plot the velocity along some line perpendicular to the surface of your airfoil (maby in the middle of the airfoil) to see if the boundary layer is resolved correctly.
RodriguezFatz is offline   Reply With Quote
Old   October 2, 2012, 11:26
Ehsan Asgari
Thanks again.
Yes, I mean that one. But in this case you need not to change anything. Only you should take into account the Re Number of your own problem and make decision whether the flow is laminar or turbulent.
As I know in most simulation flow is considered to be turbulent in Re numbers equal or higher than 100,000 .It is comparable with flat plate problem.
You should show us the grid. In laminar flow, there is a rule of thumb saying there should be at least 20 cell in adjacent the solid boundary to capture velocity Gradient(from zero to free stream) of boundary layer. But in the turbulent case, you should consider an expansion ratio equal or less than 1.2 for boundary layer cells. Of course, y+ criteria is very important in turbulence modeling and you should adjust the first cell height regarding to the y+ recommended for turbulence model in use.
In this case, I suggest Spalart-Allmaras because it usually converges fast and is appropriate if there isn't any Big! separation or steep pressure gradient in the flow. According to AOA you've mentioned below, you can use this turbulence model easily.
Old   October 2, 2012, 12:26
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
diamondx is very much correct in asking the mesh statistics, which is very much important for the drag prediction.
Far is offline   Reply With Quote
Old   October 2, 2012, 12:42
cfd seeker is on a distinguished road
Good lift and bad drag agreement is a typical representation of bad viscous mesh, so it means your boundary layer is not resolved properly. What type of mesh you are using hybrid or fully structured? what is the chord length? SST kw is the best model recommended for airfoils if the flow is fully turbulent but if the flow is transitional then you have to use 3 or 4 Equations transition models in fluent to properly capture the physics. Show us the mesh and tell your chord length so that we can suggest you proper solver settings.
cfd seeker is offline   Reply With Quote
Old   October 2, 2012, 22:21
Jonathan
Hello all and thank you very much for your replies.
Here are the pictures of my mesh. I hope they are high enough resolution for you to get the information you want.
The chord length is 1m, the mesh boundaries are 12.5 chord lengths from the airfoil and the mesh is 40,000 cells. I don't understand the terminology "unstructured", "hybrid" and "structured". When I created the mesh I followed Fluent tutorials and simply selected the number of divisions along a certain boundary and the bias type and factor.
My main aim is to find L/D max for each aerofoil and compare them. Using my current models, the AoA for L/Dmax is 2 or 3 degrees off the experimental value, which is insufficient for my purposes.
I believe I understand the maths and theory behind the models and I think Spalart-Allmaras should be sufficient. I believe my problems lies in not understanding how to use the software effectively.
Again, thank you for your help.
Old   October 2, 2012, 22:25
Ehsan Asgari
Attachment 15994
Attachment 15995
What is the y+ range Archer?
Old   October 3, 2012, 01:26
Far
Sijal
From pics, I can infer that Y+ is too large. What is the minimum and maximum Y+ on the air foil surface.
Old   October 3, 2012, 03:11
Jonathan
Showing my ignorance here.
I'm not sure what you mean by the y range.
The airfoil has a chord of 1m and thickness of 15%. The arc radius of the C-grid is 12.5 chord lengths (12.5m).
Cheers
Old   October 3, 2012, 06:48
Far
Sijal
In this range flow is transitional and you should not model is as laminar flow. Bette try to use the higher Reynolds numbers (fully turbulent flow) to get comfortable with it.
Moreover in the low Reynolds number regine boundary layer is thick and you should put the more mesh in it and with increasing the Reynolds number, boundary layer get thinner.
Old   October 3, 2012, 08:29
Philipp
Cheers
Not "y", but "y+". This is the normalized spatial coordinate, perpendicular to the surface. You can get it, when you use a turbulence model and then plot "->turbulence->y plus" in Fluent. The first gridpoint should be at about y+ = 1, except if you use a wall function (which you don't do in the viscous-laminar case). This can be a source of error.
Also: As far as I know, grid lines should always end perpendicular to surfaces - if possible. It looks like they don't do it on your airfoil.
Old   October 10, 2012, 00:12
Jonathan
Hello again.
I had to take some time off from this project to get some other work done.
I found out how to find the y+ values and I increased the number of mesh cells and the bias factor until it reduced (from about 20) to 1.
The simulation is producing better results now, but the mesh looks a bit funny to me. Does it look alright to those of you with experience? I am operating with a Reynolds number in the region of 300,000.
Cheers
Old   October 10, 2012, 06:42
Tamil Nadu
nkme2007 is on a distinguished road
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT.
Can anybody help me out, how to model and simulate?
Does any tutorials exist?
nkme2007 is offline   Reply With Quote
Old   October 10, 2012, 08:20
Philipp
Hey. To me it looks allright. But I am no airfoil specialist.
Old   October 10, 2012, 11:19
Far
Sijal
Hello again.
Cheers
Attachment 16109
Attachment 16110
Mesh looks good now. Do the sensitivity analysis
Old   October 11, 2012, 11:01
Jonathan
Sensitivity analysis?
How do I do one of those?
Cheers.
Old   October 11, 2012, 11:16
diamondx's Avatar
Ghazlani M. Ali
sensivity analysis means trying different size mesh to have an optimal mesh, less elements and without affecting solution. solution becomes mesh independent
Far likes this.
Regards,
Ali
aerofoil, airfoil, coefficient, fluent
Setting Reynolds number in Fluent for plunging airfoil quarkz FLUENT 2 November 20, 2019 00:40
fluent gets wrong airfoil vortex shedding frequency eaglexyb FLUENT 0 July 19, 2012 11:39
Want to learn FLUENT , want to modell 2d compressible flow past an airfoil diwakarsingh64 Fluent UDF and Scheme Programming 1 January 26, 2011 13:13
Simulation of a moving airfoil in Fluent M.Sc_Student FLUENT 2 October 25, 2010 04:03
how to creat a mesh in fluent for airfoil sanjay umarani FLUENT 0 March 7, 2005 06:26
