Difference between Fluent and CFX
Old   September 28, 2012, 12:19
Default Difference between Fluent and CFX
Hamed
safikhani_hamed is on a distinguished road
Dear friends,
In fact I have simulated the flow of water in a long tube with flattened sections with gravity effects, unfortunately the fluent solves the flow not correctly and I think that fluent does not uses gravity effects but I have solved this problem with CFX and CFX solves the flow field very good and CFX uses gravity effects, does anybody know the reason of this problem, the figure of a contour of CFX and Fluend is attached.
Sincerely
safikhani_hamed is offline   Reply With Quote
Old   October 1, 2012, 05:16
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Did you set your gravity force in Fluent?
RodriguezFatz is offline   Reply With Quote
difference between CFX and fluent rashmi FLUENT 17 February 3, 2020 08:29
Different result in CFX and fluent for mass trans.? is segregated better? ftab CFX 7 September 27, 2012 08:57
Difference between CFX and FLUENT TypeSpeed CFX 3 January 6, 2010 16:55
Difference between Fluent, CFX and ICEM CFD holyo ANSYS 1 July 23, 2009 11:18
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
