Materials Assigned to Walls
Old   September 26, 2012, 16:31
Exclamation Materials Assigned to Walls
Alamo
alavar is on a distinguished road
When setting up a problem in Fluent, there are materials assigned (automatically) to the walls, even though the walls have thickness of zero. I believe these material setting is not critical, i.e., I won't need to change them from the default (it seems to be aluminum, or another material I have used somewhere in my model). Can someone please confirm if my assumption is correct? (or let me know if I am wrong).
Thanks.
AM
alavar is offline   Reply With Quote
Old   September 27, 2012, 16:30
Negin Nazarian
nenazarian is on a distinguished road
It depends on your simulation.
for instance It might be used if you are accounting for thermal inertia in your case.
nenazarian is offline   Reply With Quote
Old   September 28, 2012, 14:08
Robert
Kwiaci is on a distinguished road
Yes, If you keep wall thickness equal to zero it is neglected in calculations and material doesn't matter.
Kwiaci is offline   Reply With Quote
default, materials, walls boundary conditions
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
error message cuteapathy CFX 14 March 20, 2012 07:45
materials for walls in dwelling system yy5e09 FLUENT 0 July 19, 2010 10:14
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
