Problem in getting mesh independent soluiton for flow over flat plate |
November 26, 2012, 14:58 |
#21 |
Lucky
Rep Power: 66 |
Fluent also uses the reference length to normalize the heat transfer coefficient to arrive at Nusselt number. You can't get Nux only NuL from the simple reports. Again, you can cross-compare but it looks like your code is working.
January 31, 2013, 00:03 |
grid independence studies
#22 |
santhiya
I am working on semi-confined jet impingement cooling. My impingement surface (bottom of cylinder) is at 3mm from the nozzle exit (vertical jet)and at 600k. When I do grid independence studies , the nusselt number value at stagnation keeps increasing as the mesh gets finer. I plot - nusselt number vs radial distance. Coarse mesh gives better result than finer mesh. How to get stable values! Need Help!!! |
High aspect ratio mesh problem for flat plate boundary layer | sam1364 | OpenFOAM | 3 | May 14, 2020 12:11 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Setup of flat plate problem for laminar layer | pankos | Main CFD Forum | 3 | August 9, 2011 18:37 |
Conjugate heat transfer for film-cooled flat plate | Michele | FLUENT | 0 | July 3, 2006 09:42 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
