Plotting the Viscosity Contour in CFD Post
Old   September 21, 2012, 00:40
Question Plotting the Viscosity Contour in CFD Post
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear All,
I am modelling the non-Newtonian blood flow in human arteries using Ansys Fluent. I used the carreau non-Newtonian model, however, I can't plot the viscosity contour in CFD Post.
Does anyone how to plot the non-viscosity contour in CFD post?
Kind regards,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   May 17, 2014, 04:28
Marco Dc
I-mech is on a distinguished road
Originally Posted by ashtonJ View Post
Dear All,
Kind regards,
AshtonJ
Hi, maybe you've already find your solution.
However, i'm going to suggest a solution that fit my problem. I hope it can be useful for you.
When your solution has stopped:
1. click on "Graphics and Animations"
2. under Graphics select Contours then click "Set Up"
3. Contours of "Properties" then select "Molecular Viscosity"
4. change levels as you prefer then "compute" and "display"
In my problem i have an UDF defining temperature dependent dynamic viscosity.
Looking to this contour plot i finded out that temperature field and dynamic viscosity field match.
I-mech is offline   Reply With Quote
Old   June 2, 2015, 12:51
LManes
Lemanes is on a distinguished road
I have the same problem... When I was using CFX I could calculate dynamic viscosity using this expression:
ave(Dynamic Viscosity)@Fluido
However, Now I am using Fluent to solve the same problem ( Natural convection in square cavity) and I cannot find the Dynamic Viscosity or even specific heat (cp) in CFD post... I know that I can find them in fluent results, but I want them in CFD post to calculate the rayleigh and Nusselt numbers...
Someone could help me?
Thanks a lot
Lemanes is offline   Reply With Quote
Old   June 2, 2015, 13:06
LManes
I found it...
Go to "Run Calculation", select "Data File Quantities" and then select what you need. Then run the simulation again... There are a lot of other properties there that you can select....
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 5 October 24, 2016 10:26
Guide: Getting Started with the CFD Online Discussion Forums pete Site Help, Feedback & Discussions 8 July 29, 2016 06:00
post graduate opportunity in CFD application in Military teguhtf Main CFD Forum 0 January 31, 2011 22:30
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
Contour plotting Mark Russell Main CFD Forum 5 April 22, 2000 23:45
