pressure gradient of a 2D periodic flow problem
Old   September 19, 2012, 04:21
Default pressure gradient of a 2D periodic flow problem
Honey
Honey is on a distinguished road
There is a 2D periodic problem in which the mass flow rate quantity across the periodic boundary are known and given. The pressure gradient of the domain is calculated by Fluent and displayed in the "Periodic Conditions" dialog box, as mentioned in Fluent tutorial guide. However, I have noticed that if I let my simulation to run for few more iterations after the convergence of the solution, then the displayed pressure gradient also changes. I had a "3D" problem with periodic boundaries at the inlet and the outlet which was set as mass flow rate but never faced this change of pressure gradient after convergence of solution. Can someone help and comment on how to get the exact pressure gradient in the domain using periodic boundary condition set as mass flow rate???
Thank you very much,
Honey
Honey is offline   Reply With Quote
Periodic Pipe Flow LES dvolkind CFX 8 March 21, 2020 06:30
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
pressure gradient to develop flow profile d46 OpenFOAM Pre-Processing 4 May 24, 2012 12:16
Calculation of pressure gradient in periodic boundary condition ksaat FLUENT 7 May 16, 2011 04:59
Flow not moving - Supersonic/Initial Pressure problem? shankara.2 FLUENT 0 June 9, 2009 21:49
